It is currently Mon May 12, 2025 12:10 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Apr 04, 2013 4:13 pm
I am looking into doing this.. I have a couple of questions will the stock throttle cable still work??? Would you still jet the same as stock carbs?? Also what carbs are you using or where are you buying them..
1993-97 Polaris 580 triple snowmobiles used 34 mikunis and they are cheap to buy thinking of using those?? Any problems forseen
1977 KH 400
1976 KH 250/350 rat bike
1971 KV 75
1976 KV 75
PostPosted: Thu Apr 04, 2013 4:59 pm
I'm not qualified to answer most of your questions, but I'll hip you to what I know so far:
I put sled 34's on my H2 and it made a HUGE difference in performance. I used the stock cable. I switched to pre-mix at the same time so my jetting wouldn't work for you. Possibly on the old website, I found vague-but-useful starting recommendations for jetting. I put giant, expensive K&N cones on it but will use cheap and bendable Uni-Flows for the H1.
The reason I'm not giving the 34mm a huge thumbs-up is that the engine won't idle down. It could be the fact that I've got an extremely used crank in it, or possibly due to some inlet-valve or other sled-related jetting bugaboo. This summer I'll devote more time to it, including the crank.
Huge difference in HP tho.
PostPosted: Thu Apr 04, 2013 8:23 pm
Thanks for info I think I am going to go this route not happy with the H1 carbs cant get used to all that stuff on top where just the cap should be :wtf: Like the look and getting rid of the phenloic insert for a positive seal..
Where are the rubbers being bought from to carb from adapter???
Thanks for help..
1977 KH 400
1971 KV 75
1976 KV 75
PostPosted: Sun Apr 07, 2013 10:22 am
jcsnook wrote:
These are cool looking. Any adapter will likely require some port matching. You won't need to worry about cutting any cylinder fins off or anything drastic like that with these and the appropriate rubber manifolds. I believe rubber manifolds should be available from any Sudco dealer.
I've not seen these personally...are they drilled to use the OEM H2 rubber manifolds? Sorry, can't read German. Isn't this Ralf's buddy?
http://www.ebay.com/itm/170375784460?ss ... 1438.l2649
Does anyone no where else to get these.. Appears he has no more.. Nothing listed in his store :think:
1977 KH 400
1971 KV 75
1976 KV 75
PostPosted: Sun Apr 07, 2013 1:41 pm
http://www.ebay.com/itm/69-75-Kawasaki- ... 1284wt_658
PostPosted: Sun Apr 07, 2013 4:17 pm
joker wrote:
http://www.ebay.com/itm/69-75-Kawasaki-H1-500-Triple-Denco-34mm-Carburetor-Adapter-Plates-Manifolds-/181116871957?pt=Motorcycles_Parts_Accessories&hash=item2a2b682515&vxp=mtr#ht_1284wt_658
Thanks Jeff
After seeing the upclose ,, I may attempt to make them myself... :thumbup:
1977 KH 400
1971 KV 75
1976 KV 75
PostPosted: Tue Apr 09, 2013 10:28 pm
Try lifting the needle by 1 groove (lower clip) and re-adjust the pilot/AS to suit. Bin there done that! ;)
J
PostPosted: Wed Apr 10, 2013 9:48 am
Relisted here:
http://www.ebay.com/itm/171020953033?ss ... 1438.l2661
Ad notes more than 10 available...
92 NSR250 MC21, 93 TZR250 3XV
03 ZRX 1200R
PostPosted: Wed Apr 10, 2013 12:55 pm
german translation
with this set you can put on H1 and KH 500 engine carburators from H2
The set is for 3 manifold as you see on the picture and as I describe it.
The flanges are also made with high quality alloy 7075 CNC.
PostPosted: Wed Apr 10, 2013 5:28 pm
not trying to hijack this thread.
But Was this part of the denco stage one kit ,(chambers,h2 carbs,bigger rear sprocket but no porting)?
thanks mark
