Mr. Foully wrote:
I'm not qualified to answer most of your questions, but I'll hip you to what I know so far:
I put sled 34's on my H2 and it made a HUGE difference in performance. I used the stock cable. I switched to pre-mix at the same time so my jetting wouldn't work for you. Possibly on the old website, I found vague-but-useful starting recommendations for jetting. I put giant, expensive K&N cones on it but will use cheap and bendable Uni-Flows for the H1.
The reason I'm not giving the 34mm a huge thumbs-up is that the engine won't idle down. It could be the fact that I've got an extremely used crank in it, or possibly due to some inlet-valve or other sled-related jetting bugaboo. This summer I'll devote more time to it, including the crank.
Huge difference in HP tho.
Thanks for info I think I am going to go this route not happy with the H1 carbs cant get used to all that stuff on top where just the cap should be
Like the look and getting rid of the phenloic insert for a positive seal..
Where are the rubbers being bought from to carb from adapter???
Thanks for help..
