To All
This does not look good at all
........I have just started having some transmission 1st gear issues........pulled the motor and opened it up.......figured bent shift fork and burned.......found several issues, crank bearings wasted and now a hairline crack with the small needle bearing goes on the output shaft boss (sprocket end) of the trans where the dowel pin sits, which is somewhat oblonged and a bit loose now
the crack as you can se comes in sideways and is also starting vertically at a 90 degree angle
I am sure this is a really stupid question, but I will ask anyways.......has anybody ever been able to heliarc this and remachine ?.......or basically start looking for a set of cases
Also, a bit of galling on the left crank boss (maybe not bad), and on the right side (maybe not to bad either).....the bearings never spun
OR DOES ANYBODY HAVE A SET OF H2 CASES FOR SALE.....Please PM me if so.......there is two sets on EBAY, one has had the pins pushed in and the other looks really rough
Please advise and thank you guys very much......Phil Mosher
