It is currently Fri May 02, 2025 5:58 pm
PostPosted: Sun Feb 09, 2014 9:27 pm
http://www.youtube.com/watch?v=DAGUMU8W ... video_user
PostPosted: Mon Feb 10, 2014 7:15 am
After that .....paint it...because the rust will come right back in a short time.
PostPosted: Mon Feb 10, 2014 8:07 am
Once I saw that they couldn't even spell CHROME correct in the title, I could only watch the first 30 seconds or so before exiting. Lame..... :thumbdown:
“Jeff and Chris are THE MEN!”
RIP John E. Evans
PostPosted: Mon Feb 10, 2014 11:24 am
A good coat of wax would work.
PostPosted: Mon Feb 10, 2014 1:37 pm
I like to soak parts in oxalic acid to remove rust. You can buy oxalic acid on e-bay for cheap and it works great.
PostPosted: Mon Feb 10, 2014 5:58 pm
The reason for having chrome in the first place is it's low maintenance. You could of course wax or keep coated with something. Hence, I'd paint it !
8-)
PostPosted: Mon Feb 10, 2014 6:33 pm
Chrome should be waxed anyway..........
PostPosted: Mon Feb 10, 2014 6:54 pm
Mike - I use Oxalic Acid to remove corrosion. It is also known as Wood Bleach and is available at Ace Hardware here in the midwest. It is cheap and works very quickly.
As the OP said - good for the 10 foot job. The pits in the chrome stay. Only the ferrous oxide is removed. Wax is a must after that.
Tip: Never polish anything metal with steel wool. It leaves tiny iron findings in small pits. These will bloom rust very quickly.
Rotortech
Indianapolis
1974 S3
