It is currently Tue May 13, 2025 2:57 am
 Post subject: Re: Fun in the garage
PostPosted: Fri Oct 11, 2013 11:43 pm
Quote:
Trevor, is that an early or late CBX, (colour?), and what have you got for an exhaust system? Spent a bit of time on a silver 1st model, when they first came out!!
1978 silver twin-shock. Marving (Italian) 6-2 mild steel exhaust system. The Marving works very well but it's too bloody quiet! One day I'll put a Pipemasters 6-6 stainless on...
PostPosted: Sun Oct 13, 2013 9:04 am
HA !
Wait until you get around to rebuilding the carbs. And then ya get to sync'um !!!!
:crazy:
PostPosted: Mon Oct 14, 2013 1:32 pm
Ric wrote:
HA !
:crazy:
I rebuild carbs all the time, but I think I would rather have a severe beating then take on a CBX. I am told that the engine needs to be leaned forward from the rear mount just to remove them.
TOOLS
PostPosted: Mon Oct 14, 2013 1:57 pm
Holley 680...... :lol:
PostPosted: Mon Oct 14, 2013 2:39 pm
OH, PUHLEESE!! Go fuel injection. Megasquirt with a single 65mm throttle body. :mrgreen:
PostPosted: Mon Oct 14, 2013 3:49 pm
FO... FI.......... :lol: :lol: :lol:
PostPosted: Tue Oct 15, 2013 6:13 am
You also have to do that to replace a throttle cable...
PostPosted: Thu Oct 24, 2013 12:55 am
I finished the CBX valve adjustment. I must say that I'm impressed with the precision of shims over screw-and-locknut. As long as you're very precise with your measuring you can achieve a very precise valve clearance. However, I thought I would pass along something I learned along the way.
Shims are not the same size as the number printed on them! I needed four 275's (2.75mm). Silly me ordered 4 x 275's. I got four shims with 275 printed on them, but in reality I got 1 x 272, 2 x 273 & 1 x 274. So it turns out that shim numbers are printed to the nearest multiple of 5. A 275 will probably never measure 2.75mm. Luckily, the place I order shims from also stocks 1/2 size shims. I ordered 3 x 278's. I got three shims with 278 printed on them, but in reality I got 2 x 275 & 1 x 276, which worked out perfectly.
Trevor
PostPosted: Thu Oct 24, 2013 6:59 pm
TOOLS1 wrote:
Ric wrote:
HA !
:crazy:
TOOLS
Rotating the engine is really pretty easy and works great.
