It is currently Tue Jul 08, 2025 4:34 am
Post new topic Reply to topic  [ 2257 posts ]  Go to page Previous  1 ... 52, 53, 54, 55, 56, 57, 58 ... 226  Next
PostPosted: Fri Feb 24, 2012 2:51 pm
Apart from beer, spokes for my F5 :thumbup:
PostPosted: Fri Feb 24, 2012 6:20 pm
H1A 500 and 3 nos 5GL03 needles on ebay.
PostPosted: Fri Feb 24, 2012 6:36 pm
Hello!
1975 Yamaha RD125B
1978 Yamaha RD400E
1978 Kawasaki KZ650B
PostPosted: Sat Feb 25, 2012 9:51 pm
JoeMcdonald wrote:
Quote:
Where did you get them? Make,model,part number? I'd like to try some as well.
http://www.aaenperformance.com/snow_exhaust.asp
7" - 1 2.25" Body SIL14501 $69.00
My stinger is a 1'' O.D.
After rereading the website they say the core inside the silencer is the same od as the stinger. That seems right as the stinger can only go inside the silencer by about an inch then butts up against the core. That also means the stinger is extended by the core length.
Thanks
PostPosted: Sat Feb 25, 2012 10:24 pm
Joe,they are your pipes but I wouldn't modify those stingers !!!! I guess you already know,but they are the Rare Taper Head TNT stingers !!!
PostPosted: Sun Feb 26, 2012 10:12 am
A Samsung SH100 pocket camera, I shot above using my old tab. The lighter is just to demonstrate the size. Very handy, you can e-mail pics using wi-fi where ever available, straight to photobucket. Below please find a sample pic just to show the quality:
PostPosted: Sun Feb 26, 2012 9:26 pm
New tractor. That's me at the cab door, standing are my boys & father. Could buy a whole pile of NOS triples for what this cost.
PostPosted: Sun Feb 26, 2012 11:14 pm
Give us some specs please. Displacement, HP, Max RPM, number of turbochargers, weight, etc.. Nothing like a late model 4WD huge tractor. Do you still fill the tires with antifreeze on the big ones?
PostPosted: Mon Feb 27, 2012 4:31 am
1050 hrs (that's low)
18523 lbs
205 factory HP (could be turned up)
Yes there can be liquid ballast inside tires. This machine has enough weights.
From tractordata.com:
Engine:
Type: John Deere inline
Fuel: diesel
Aspiration: turbocharged aftercooled
Cylinders: 6
Bore/Stroke: 4.56x5.06 inches [116 x 129 mm]
Displacement: 496 ci [8.1 L]
Cooling: liquid
Coolant: 35.9 qts [34.0 L]
Compression: 16.5:1
Rated RPMs: 2200
Torque: 741 lb-ft [1004.8 Nm]
Oil capacity: 29.6 qts [28.0 L]
All kinds of newfangled stuff this thing has. Like the Implement Management System (IMS), scv touchset controls,automatic power shift mode.
The IMS is amazing in all the things it can do, what I'll use it for is, program Up&down & depth of tool, speed, gear range etc. That way when wifey is helping all she will have to do is push a button, turn around & push button again.
The fuel tank is 135 gallon so at $4 diesel a fill up costs $540 !
PostPosted: Mon Feb 27, 2012 10:02 am
Thanks for the neat information. I searched a little and found one you left out: the 3-point hitch lift capacity is nearly 6 tons! I love that you've already planned to set it up for your wife.
