Give us some specs please. Displacement, HP, Max RPM, number of turbochargers, weight, etc.. Nothing like a late model 4WD huge tractor. Do you still fill the tires with antifreeze on the big ones?
1050 hrs (that's low)
18523 lbs
205 factory HP (could be turned up)
Yes there can be liquid ballast inside tires. This machine has enough weights.
From tractordata.com:
Engine:
Type: John Deere inline
Fuel: diesel
Aspiration: turbocharged aftercooled
Cylinders: 6
Bore/Stroke: 4.56x5.06 inches [116 x 129 mm]
Displacement: 496 ci [8.1 L]
Cooling: liquid
Coolant: 35.9 qts [34.0 L]
Compression: 16.5:1
Rated RPMs: 2200
Torque: 741 lb-ft [1004.8 Nm]
Oil capacity: 29.6 qts [28.0 L]
All kinds of newfangled stuff this thing has. Like the Implement Management System (IMS), scv touchset controls,automatic power shift mode.
The IMS is amazing in all the things it can do, what I'll use it for is, program Up&down & depth of tool, speed, gear range etc. That way when wifey is helping all she will have to do is push a button, turn around & push button again.
The fuel tank is 135 gallon so at $4 diesel a fill up costs $540 !
