It is currently Fri May 02, 2025 10:58 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Mon Oct 24, 2011 11:31 pm
Been lax on the updates......I've worked twenty nine of the last thirty days with an afternoon off to ride with a new friend fom the boards. I have acquired a few more bits to the growing pile (which is becoming harder to hide all the time :lol: )
From Volker in Germany http://hard-to-find-parts.de/
From Rainer in Germany http://stores.ebay.de/braram1290?_trksid=p4340.l2563
Both Volker and Rainer get a thumbs up for quality and service.....I would buy from either of them again.
PostPosted: Tue Oct 25, 2011 12:51 pm
I don't want to cause any undue concern, but...that AIN'T the only place those frames have "hinges".
PostPosted: Tue Oct 25, 2011 7:32 pm
True but I will do the best I can with what I have. If I was building a track only bike I would slow down and have Randy build a frame but that isn't my goal. I just want to do a build properly for once with some thought/help and do some track days on a triple with a few good friends who ride modern weaponry. Just have another nice bike to enjoy that won't have another one like it park next to me at the bike nights. :D
PostPosted: Sat Oct 29, 2011 7:02 am
Walms is in the house.....really :lol:
think we can make these
Into these?
PostPosted: Sat Oct 29, 2011 11:07 am
Looks like a "Conehead" reunion at "Coney Island".............. :lol: :lol: :lol:
PostPosted: Sat Oct 29, 2011 11:43 am
I'm glad they madE it there in one piece.... So to speak. :mrgreen:
This software might be helpful to you if you plan to tweak the layout.
I've never used it but I'd imagine it would get'er done.
http://www.pulserate.com/
PostPosted: Sat Oct 29, 2011 11:56 am
I use the Pulserate Cone Layout program ^. I like it enough that I paid for a registered copy. It runs on Linux, using WINE, is easy to use, and generates DXF files or prints directly.
PostPosted: Sun Feb 05, 2012 12:12 am
Time to catch up again. I've spent a lot of time studying up, reading about this and that etc. and have acquired an even larger pile of stuff I won't bore you with :lol:
Got a set of Jim's caliper adapters and a pair of really nice calipers set up using Magic
I was hanging out with a good friend over the holidays helping him re-restore his RC30. He bought it at the same time I picked up my current H1 twenty plus years ago. He wore the Honda out already ;) He was upgrading the front brake system and while we were talking I mentioned I was looking for a remote reservoir master for the triple. He opened his toolbox and handed me the RC30 master...wouldn't take anything for it. Just told me to use it in anger proudly. :D The RC has a storied race history and I'm proud to use it. The only Honda using the correct brake lever and a mechanical clutch is the CBR900RR so I picked up a perch and a set of matching levers. Also the CBR900RR kickstand because it was cheap, it may work and came with a free aluminum block. Also a rear brake cable in black....seems the cable will be easier to work with than an arm when fabbing rearsets.
He also found/returned my timing plank I made for my Honda 50 years ago
After much looking I opted for the WoodCraft three piece clip ons. I would suggest you add these to your short list if you ever need a set. The three piece is nice because you don't have to pull the tubes to remove them, they are super well made and made in the good old USA.
My new Sun rims should be here in a couple weeks so I got a KH500 front hub and the KH400 rear hub looking spiffy and new sealed bearings installed
The swingarm is set up and the rake is adjusted.....here's how the critical mass sits today
Going to add a hoop under the tail and tack some thin sheetmetal on there. I am using the tiniest battery I can get away with. I want to put the battery and oil tank under the bubble butt to hide them completely. I will "open" up the vertical area of the tail and the seat pad will just cover the opening. I am going to design (successfully I hope) a sort of horseshoe shaped oil tank and use the tank itself to hold the battery....the tank bung will be just inside the opening. That's how I vision it anyway. Found a good spot to mount/hide the coils and iggy boxes. So many little things to think through :roll:
Picked up a set of Jim's carbon cans for the WTF's.....next update should be pics of how that turns out. my FZR 400 rear axle is bent........and NLA. Yamaha part# 3FH-25381-00-00 I need a 16mm rear axle at least 12.5" long, preferably a thru drilled part....if its longer I can cut it and reweld the head back on. If you know of a bike using one I could try that one.....will be cheaper than having one made so if you know of one give me a shout. :thumbup:
Oh......got my fairing pre mounted as well
PostPosted: Sun Feb 05, 2012 4:51 am
hard work :thumbup:
PostPosted: Sun Feb 05, 2012 9:21 am
Looks like things are coming together Dan! 8-)
I'm looking forward to seeing this funky layout you have planned for the pipes!
