It is currently Thu May 01, 2025 1:46 pm
 Post subject: Ivan's Holiday Sale 2011
PostPosted: Fri Nov 25, 2011 11:03 am
Holiday Sale !!
Monday November 28th through Saturday December 24th.
Sale dates will not be extended
Sale prices are offered to purchases made during sale dates only
Carb Kits 15% off
Sale does not apply to FZ1-POD Carb Kit or FZ-1 ported intake boots
Thanks for all your business guys !! :thumbup:
Happy Holidays to you and your family !! :thumbup:
Ivan
845-268-1212
M-F 10am - 6pm
Saturday 10am - 2pm Eastern time
www.ivansperformanceproducts.com
PostPosted: Fri Nov 25, 2011 11:41 am
Hello Ivan,
I have seen your H1 carb kits designated for years 72'-76', will they work on the early H1's?
Cheers
tim
PostPosted: Fri Nov 25, 2011 12:54 pm
I would be shocked if it didn't work.... the key here is to use both my needles and needle jets.
I haven't tested it in an older bike, but the porting/exhaust didn't change significantly enough to affect the jetting throughout the years.
The significant thing that changed is the height of the primary choke from early to later models.... this will affect throttle sensitivity in the first half a turn on the throttle.
The shorter the height, the more sensitive it will be..... this also affects main jet size and the entire fuel slope at wide open throttle..... on really thirsty 2 strokes, a shorter primary choke may not deliver enough fuel at wide open throttle...... (warranty issues or the need for a power jet), also a shorter choke may cause the needle taper to change..... It did not need changing on my T20 X6 Hustler, but did on my TC200 when the chokes were made shorter.
In the spring, I will get a set of the early carbs and set them up on my bike with my current parts and compare the differences.... I will offer the parts for them if there is a noticeable difference in performance.... if not the kit will be for all years.
Ivan
PostPosted: Fri Nov 25, 2011 6:05 pm
Are there two different kits here - Jet Kit and Carb Kit? If so, what's the difference in parts and price?
Quote:
Kawasaki H2 750 Jet Kit - Available now !!
Kawasaki H2 750 Carb Kit
Part #H2-7275
Price $225.00
PostPosted: Fri Nov 25, 2011 8:13 pm
No difference.... same thing.
I just wanted them to show up easier when a search is done.
Ivan :)
PostPosted: Mon Mar 26, 2012 11:24 am
Hi Ivan, are you still doing H2 carb kit.
I need one and goes to the man who sells your kit in Uk but he has only modern bike jet kit :(
PostPosted: Mon Mar 26, 2012 12:48 pm
I have them... I will sell it directly to you.
Send me a PM and we can do it through paypal.
Ivan
PostPosted: Tue Mar 27, 2012 3:52 am
Ivan PM sent :mrgreen:
PostPosted: Tue Apr 03, 2012 11:10 am
Hi Ivan,
payement done and thank you. 8-) :mrgreen:
PostPosted: Thu Apr 12, 2012 2:08 am
received the parcel yesterday wesneday april ,11th.
Thanks Yvan :thumbup:
