It is currently Wed Apr 30, 2025 11:42 am
PostPosted: Thu Jan 02, 2025 1:23 am
I'm pretty sure this is the correct routing for the stator wiring harness. Can someone please verify it? I'm also assuming that it's secured by a harness tie band.
PostPosted: Sat Jan 04, 2025 8:43 am
This what I ended up with. I routed things as clean and accessible as possible. One fella on the FB KTOG said and he is right, "it's not a factory rebuild so just run it like you want. Also need to state that the electrical harness is from a H1-D.
PostPosted: Sat Jan 04, 2025 8:46 am
PostPosted: Thu Jan 30, 2025 2:57 am
1st of all that's a D
Secondly the back engine mount bolts need turning around, when you fit the sprocket cover it will hit the nuts and break it
PostPosted: Thu Jan 30, 2025 3:17 am
You are correct on both accounts. I corrected the rear engine bracket bolts when I tried to install the cover. Although the title, frame and engine are E's. The ignition system is from a D model.
PostPosted: Thu Jan 30, 2025 7:24 am
Have you checked the engine and frame serial numbers in the chart?
https://kawatriple.com/serialno.html
PostPosted: Fri Jan 31, 2025 6:43 am
Well I double checked the numbers. Guess I forgot. The frame is a late 74 and the engine is mid 73.
