H2RTuner wrote:
Please do it the right way, buy, and use a Uni-Syn. It's a lot easier, and far, far more accurate than any manual measuring of slides in throttle bores.
+1
The trick to the unisyn is it can only be applied to the carb mouth for about a second before it drags the engine speed down. One must let the engine speed re-stabilize before checking the next cyclinder's carb.
There are actually two separate carb syncs you must do:
The first is with the throttle slides at rest on their idle stops, to attain the desired idle speed. A perfect flow sync (by taking brief unisyn measurements) here gives the quietest (non rattlingly) engine possible.
The second sync is the actual slide operation as dictated from the cables. This is what your engine is operating with during riding. A perfect flow sync here gives the smoothest (least vibration possible). Adjust this after you have completed the above idle sync.
First adjust the cable slack at the cable adjuster at each carb to give around 1-2mm (equally) with slides on their idle stops. Start the engine. Adjust the twist grip mounted cable adjuster to take all the slack out of the cable system and continue adjusting until the engine speeds up to around 3-4000 rpms (the slides are now being lifted by the cables). With the engine speed stabilized take a uni sync reading on each carb, one at a time. Adjust the cable adjuster at the
carb until all readings are identical between cylinders. Lock the adjusters with their lock nuts when done.
Now back off the adjuster at the twist grip until about 2-3mm slack is in the cable here (slides are now returned on to their idle stops hence returning engine speed to desired idle) and LOCK the adjuster with the check nut. Be sure enough slack is left at both the twist grip cable adjuster (2-3mm) and the carb mounted cable adjusters (1-2mm) so that no increase in rpm occurs with turning the handle bars lock to lock.
Finally after you have adjusted the cables as above re-check/adjust your oil pump setting as it may have changed.
J
PS, I suggest you take the bike out for a run to clear any excess oil out of the crankcase and get the engine to normal operating temp first. Also be sure the bike is level (on center stand) or side stand blocked up to near level. Cables in good condition (no frayed wires or harsh bends/kinks) and properly lubricated is a must too.
