It is currently Sun May 04, 2025 10:42 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu Jul 21, 2016 2:33 pm
I have been spray copper coating my aluminum crush washers for a couple of years now and they simply don't leak, just another way to skin a cat :)
1977 KH 400
1976 KH 250/350 rat bike
1971 KV 75
1976 KV 75
PostPosted: Tue Jul 26, 2016 1:39 am
the stock pump uses a heavy mix ratio like 24:1 so buy oil that is made for it. dino tc3 is perfect really. the fancy premix oils are too much at that pump ratio and will load up, foul plugs, etc. myself, I much prefer premix only and ditch the pump. no leaks, and if motor is running its lubing. I flog my motor and its still going strong after 10 years and 5k hard miles. Engines die for lots of reasons so dont assume magic oil will save you!
PostPosted: Tue Jul 26, 2016 8:09 am
Mine's dead stock John, and averages about 50:1. I'm sure it's at least 24:1 when fully open, but less than 50:1 when cruising.
PostPosted: Tue Jul 26, 2016 11:28 am
From an oil thread on KTOG:
h2rtunerdave wrote:
The way the pump is designed is that @ idle, the oil ratio is 100:1, and at WOT, 20:1.
PostPosted: Tue Jul 26, 2016 11:32 am
That sounds right. I wouldn't be surprised if a steady 60 mph on my H2 gives somewhat less oil than 50:1.
PostPosted: Tue Jul 26, 2016 12:58 pm
That's a good testament coming from you Mark. I'm not married to Yamalube but it's a known oil for me having used it forever.
I looked up local Autozone cost here - about $7 with tax. I can get a gallon of Yama2S off the internet for just a bit more than that.
BUT ---- I might try the Castrol anyway just for grins.
Thanks,
bb
