It is currently Sat May 03, 2025 11:53 am
 Post subject: S series ignition swaps?
PostPosted: Tue Jul 19, 2016 12:22 pm
Would a 72-73 S2350 charging rotor and ignition/ point plate bolt up to a 77 KH400 crank and engine cases? If so are all parts interchangeable? Have a great week members!
PostPosted: Tue Jul 19, 2016 1:25 pm
If you mean exchanging everything from the engine case out, including the alternator housing, yes.
PostPosted: Tue Jul 19, 2016 6:36 pm
yup. and you can fit an h1E ignition if you want as well
PostPosted: Tue Jul 19, 2016 11:57 pm
Thanks for confirming that this will work guys!
PostPosted: Wed Jul 20, 2016 9:48 am
Would you not have to change just about everything else ??
Points to 77 KH 400 CDI,, same as swapping on a S3 400 to KH 400 ??
1977 KH 400
1976 KH 250/350 rat bike
1971 KV 75
1976 KV 75
PostPosted: Wed Jul 20, 2016 10:56 am
It sounds like your CDI is shot? There are some new made parts available. And with the conversion, there will be wiring adaptions.
PostPosted: Wed Jul 20, 2016 5:21 pm
Yes, it is the same as KH400 to S3.
RH controls need to be changed along with wiring harness, ignition coils. etc.
