It is currently Thu May 01, 2025 2:06 pm
PostPosted: Thu Sep 08, 2011 12:14 pm
I'm looking for the oil tank side cover knob mount that screws to the bottom of the cover with 2 screws. It doesn't need to be mint, just usable. Somehow the previous owner cracked one of the screw mounts off of mine...
PostPosted: Thu Sep 08, 2011 1:13 pm
It's spot welded on, isn't it?
PostPosted: Thu Sep 08, 2011 3:43 pm
Yep, and subject to vibration stress!
PostPosted: Thu Sep 08, 2011 3:48 pm
I had my battery cover's spot welds come loose this year. I got back to the cover no more that 10 minutes after it fell off, but true to the rule, it had already been run over. The sucker is TIG welded all around now, but needs a bit of body work.
PostPosted: Thu Sep 08, 2011 4:10 pm
Of course it is . . . :clap:
Which is why they make repops now :thumbup:
They ain't cheap at around $30 a piece - but better than the alternative :think:
PostPosted: Fri Sep 09, 2011 8:41 am
Came close to loosing mine, I had nice paint on the covers so did not want to weld it. Used a rivet to re-attach - they ain't coming off now.
For knobs I went to the local hardware store and found some really nice black ones for about 6 bucks. I had to re-tap the bungs on the frame to match the threads but works great and looks better!
PostPosted: Fri Sep 09, 2011 9:30 am
He said bung.... heh, heh, heh, ... 8-) 8-) 8-)
PostPosted: Fri Sep 09, 2011 2:41 pm
Hmm, good to know. I'm guessing the previous owner drilled and screwed mine on, didn't use the rubber mount and subsequently broke it. I checked Reproduction Decals and didn't find the re pops. Where can I get these (R.B.)?
PostPosted: Fri Sep 09, 2011 3:52 pm
Now I get it tim - some strange VA twist - bung [hole], sick sick sick - you are all sick! How'd you know I'm from San Francisco? :e11
PostPosted: Sun Sep 11, 2011 5:36 pm
Where can I get one of these? Can't seem to be having any luck finding them
