It is currently Fri May 02, 2025 6:49 am
 Post subject: Every Gasket??
PostPosted: Sat Jan 31, 2015 7:12 am
I am beginning the reassembly process on my motor. I had ordered one of the "every gasket" sets. To my surprise, it does not contain "every" gasket! It does not have the gaskets for the oil passage check valves (Part part number 14051-003) on the bottom of the case :o :evil: . I just had to cut my own. Not a problem, but kinda pissed me off.
75 H1
78 CB400II Hawk
78 KE175
 Post subject: Re: Every Gasket??
PostPosted: Sat Jan 31, 2015 8:06 am
If you have a later model triple, gaskets are an issue, but Vesrah gasket sets are the best get for a re-build, they are O.E.M.
PostPosted: Sat Jan 31, 2015 1:37 pm
H1Steve, check your pm for a link I sent you.
PostPosted: Sat Jan 31, 2015 3:34 pm
Thanks for the replies. I used the Vesrah kit and was missing these. I've already cut my own and am good to go. I was just frustrated to have to do that when this was the "every" gasket kit. I won't spend more money on another set at this point, but thanks.
75 H1
78 CB400II Hawk
78 KE175
PostPosted: Sat Jan 31, 2015 4:12 pm
It's a "every gasket set" for H2/A, not B/C as far as I know.
PostPosted: Sat Jan 31, 2015 4:23 pm
Ha.
You're absoøutely correct. The marking on my same kit spesifically says H2 1972-1975.
PostPosted: Sat Jan 31, 2015 5:16 pm
You are not really supposed to take those off, so that's why there are not gaskets in the kits.
PostPosted: Sat Jan 31, 2015 5:23 pm
Now you tell me! :banghead
75 H1
78 CB400II Hawk
78 KE175
PostPosted: Sat Jan 31, 2015 7:21 pm
block-off plates perhaps? There you go JA -- start machining!
PostPosted: Sun Feb 01, 2015 12:33 pm
