It is currently Sat May 10, 2025 7:18 pm
 Post subject: kh 500 pickups
PostPosted: Fri Aug 22, 2014 9:07 pm
Needing both pickups for a 76 kh 500. I have no spark and both pickups ohm bad.part numbers 21152-004 as 21152-005. I located good parts. Thanks h1f
 Post subject: Re: kh 500 pickups
PostPosted: Sat Aug 23, 2014 1:18 am
What's the ohms. I have one pick up
PostPosted: Sat Aug 23, 2014 1:25 am
They are supposed to ohm at 130 together or 260 separately. I can't get these to ohm anywhere remotely close to that either together or seperate. I'm pretty sure I know how to use my fluke meter cause the stator is supposed to ohm at 116 and mine is 120 so that's good. The meter is showing 2.5m so I think that's 2500.
PostPosted: Sat Aug 23, 2014 10:40 am
2.5m is 2.5 million Ω. 2,500 would be 2.5k. 2.5m is essentially open circuit, and means broken windings internally.
