It is currently Thu May 15, 2025 9:40 pm
PostPosted: Tue Aug 12, 2014 2:24 pm
Hello to all
I'm Italian in Rome, I mounted mufflers Figaroli 'm looking for information for a correct carburetion my Kawa has the original carburetor mikuni VM30SC whit jets original
Some kind user experience in this field?
Unfortunately in Italy Mikuni parts for vintage motorcycles are hard to find I would also have some link to buy any jets
PostPosted: Tue Aug 12, 2014 4:34 pm
There are 3 members showing their jetting specs at this link:
http://kawi2strokes.com/forum/viewtopic.php?f=14&t=131
Of course, there is always more in-depth information links found here:
http://kawtriple.com/mraxl/carbtuning.htm
PostPosted: Wed Aug 13, 2014 3:53 am
Figarolli for H2 are rather rare outside Italy.
Can't believe you can't find mikuni main jets in Italy :!:
PostPosted: Wed Aug 13, 2014 10:10 am
Thanks for the response kawi3cyl
I've already read your link but do not help me, I'm looking for the complete setup to avoid making numerous tests
PostPosted: Wed Aug 13, 2014 10:17 am
Of course husson73 they are Italian but Figaroli had created especially for the American market.
In Italy I find parts Mikuni main jet type but I can not find the needle jet and needle that are important for proper carburetion, I found the kit Ivanperformance but it is now available
PostPosted: Wed Aug 13, 2014 3:08 pm
well with expension chambers and standart carbs you can use the standart needle jet and jet needle (don't say you will have the standart set up but w or w/o expension chambers each bike needs its own set up). Ivan's kit is a solution works great.
PostPosted: Thu Aug 14, 2014 4:26 am
Thank you husson73,
In fact I am waiting for the kit to Ivan, unfortunately, are back with deliveries, I hope to have it for September.
Unfortunately removing the carburetor I noticed that the needle jet are not all the same: I have a 171-O6 and two 222-O6!, the 171-06 are nowhere to be found.
PostPosted: Fri Aug 15, 2014 6:58 am
needle jet is 220#0-2 (or 0-6 on KH 400) on s serie and KH 250, if yours have on 2 carbs 222#0-6, can't work on H2 which uses as you wrote 171#0-6 :shock:
Ivan kit is really good and plenty of frenchs who ride their H2 use them with very good result after the usal set up on the carbs (smooth engine, fuel consomption better and less or no more wobble). 8-)
PostPosted: Fri Aug 15, 2014 5:13 pm
I don't think the needles have been available for many years.
In the states we find them in old wasted triple carbs or use Ivan's kit.
PostPosted: Sat Aug 16, 2014 2:42 am
Exactly the 171-O6/8 can not be found
The needle jet Ivan, I think, is a clone of the 171
In my research I noticed that for the new series offers Mikuni VM30 a needle jet 169-O6/8 with external measurements identical to the old 171, but internally I am not allowed to know.
I'm tempted, while I wait for ivan kit, try the 169 which is easily found in all sizes
