It is currently Wed May 14, 2025 12:30 am
PostPosted: Thu Jul 31, 2014 8:15 am
Jeez Alisdair, stop talking about it and post the pictures nuh.
Lisa
PostPosted: Thu Jul 31, 2014 8:59 am
sparkplug is specific, have stocked two in care if by extraordinairy I will buy one (always thinking of but as you imagine already too much bikes, projects and basket cases :D ) 8-)
PostPosted: Thu Jul 31, 2014 10:07 am
Oh, yes, that spark plug, 18mm (if I remember correctly, as it has been literally decades since I have seen the original plug for my Toad-ary), tapered seat. What I did was to fabricate an aluminum spark plug adapter that has the correct threads inside and out, so it threads into the rotary housing, and holds a 3/4 inch reach regular NGK spark plug, nothing special.
The heat range is cold, down around a 9 to 9.5 NGK range. Although the ignition is a point triggered CDI, keep the plug gap down, .025 is just fine. DO NOT USE A PROJECTED TIP TYPE SPARK PLUG.
IF the thing keeps fouling spark plugs, fix the carb, float level (actual liquid fuel level in the carb bowl), jetting, and/or power port setting.
PostPosted: Fri Aug 01, 2014 12:42 am
thanks for info again I will be setting carby and power port , before I even start them as thats the way I do things , I was getting plug adaptors from Jess at R/R , so I can use normal plugs , what heat range are you using ?, urs Al
PostPosted: Fri Aug 01, 2014 12:56 pm
Please read up on the power port setting, it has to be done with a protractor scale that affixes on the primary throttle shaft, reads 20 degrees of shaft rotation, port opens.
