It is currently Sun May 11, 2025 10:41 pm
 Post subject: gearbox bearings
PostPosted: Mon Mar 10, 2014 11:13 pm
Hi,Can anyone tell me if there is anywhere I can buy the 2 needle bearings for the input and output gearbox shafts on an H2B750 part part number 92046-010, the other resource site number associated with these bearings is KT202513 they are obsolete at Kawasaki and are not available at the moment at partzilla Cheers Hooter. :banghead :banghead
 Post subject: Re: gearbox bearings
PostPosted: Tue Mar 11, 2014 5:00 am
http://www.redlinemotorsports.net/
PostPosted: Tue Mar 11, 2014 5:33 am
Thanks Mate I appreciate the help are they genuine nos or reproductions do you know??Cheers Hooter. :eh: :eh:
PostPosted: Tue Mar 11, 2014 1:20 pm
I believe they are aftermarket equal to or better than OEM. I have them in my H2 trans, including the small roller bearings too. Check to see the condition of your countershaft sprocket spacer too (fits behind sprocket) and order a new one from them at the same time if you need it. I think they also have the skinny O-ring that sits behind the spacer too, so definitely get a new one of that as well. Go through their entire inventory to see what else you could use. :thumbup:
PostPosted: Wed Mar 12, 2014 1:32 am
Good to hear someone has used the product and it works,great company that Redline Motosports, Cheers for the info Hooter. :D :D
PostPosted: Wed Mar 12, 2014 6:08 am
I bought a clutch basket bearing from redline, I assume the same supplier as it is obsolete?
It's been working quietly for 5 years now.
PostPosted: Fri Mar 14, 2014 12:46 am
Larry helped me get my crankshaft together. Chris Ritchie get the credit for his wonderful viton crank seals my he rest in piece.
PostPosted: Tue Mar 18, 2014 5:16 am
That crank looks so sweet the seals fit perfectly in there masterful machining Cheers Hooter. :e12 :e12
