It is currently Mon May 12, 2025 7:19 am
PostPosted: Sun Aug 21, 2011 9:27 pm
Hi Guys- Wasn't sure where to post this so here it is. I have two 100 cc 2 stroke Kawasaki motorcycles from the mid 70's. The Kh100 ran good last year and for a short time this year. It would idle nice but miss at 1/2 throttle and above. Now i can't get it to run at all. I had cleaned carb last year and ran great. When it malfunctioned I put a set of points in and it started then quit. I replaced plug and it started, then quit and won't restart. Will not fire on ether either. The Ke100 has the same symptoms however I also installed a new condenser in it. I just can't figure out what I'm missing.
Thanks
PostPosted: Sun Aug 21, 2011 9:47 pm
This was written for Triples but it applies:
http://3cyl.com/mraxl/trouble/basic_troubleshooting.htm
PostPosted: Sun Aug 21, 2011 10:13 pm
What time do you want me to come over?
sounds like pluged jets , bad or pluged fuel valves(needle-seat)or stuck float.
check spark,timing
Pull gas line off at carb and check for fuel.
call me when you are ready for some help.
Mark
PostPosted: Mon Jun 10, 2013 9:24 am
I've got a 73 KE-100 that ran when I bought it, then encountered some issues. Changed out entire carb, and fixed fuel tank and line and filter. Now it won't kick over... The lever is stiff and won't turn more than a few degrees. Wondering if this is an oil issue or something else. I'm at a loss as to what it is, any ideas?
PostPosted: Mon Jun 10, 2013 12:36 pm
Pull the plug and try to hand turn the flywheel.
PostPosted: Fri Jun 14, 2013 12:08 pm
Something else to check, these are rotary valve engines. The valve is a large disk with a window in it, under a cover behind the carb. Early bikes used a fiber disk that has been known to disintegrate. If you pull the carb off, you can see the disk, and will be able to see if it's in one piece or not as you turn the engine over.
Also be sure to set the point gap correctly. Changing the point gap will change the timing, and will affect how it runs.
If I had to guess, I'd say either gas or oil leaked down into the crankcase, and you're getting a hydrolock. Pull the plug and give a try. If that doesn't make any difference, it only takes 4 bolts to remove the head and cylinder to take a look in the crankcase. The head gasket is reusable, and the cylinder base gasket is still available for around $5 from the local Kawasaki dealer.
