It is currently Mon May 12, 2025 9:02 pm
 Post subject: Re: 65 Corvair
PostPosted: Sun Jun 09, 2013 10:18 pm
I NEARLY :shock: rolled an early VW, which had the same single joint rear susp. as the early Corvairs. I was 17 but I can still remember! :lol:
PostPosted: Sun Jun 09, 2013 10:37 pm
RN was reasonable well discredited by the time it was all over. Funny how it all came down to recommended tire pressure.
PostPosted: Sun Jun 09, 2013 10:42 pm
That's right Jim, I think it out-cornered whatever else was around at the time. The '65 Corvair Corsa, Beautiful looking car for the time, "strange" how they look so dated now!!
PostPosted: Mon Jun 10, 2013 6:39 am
PostPosted: Mon Jun 10, 2013 7:22 am
Cheers, Ric, great pic! Looks like '65 was the year they changed the rear suspension. :thumbup:
PostPosted: Mon Jun 10, 2013 8:54 am
In all fairness Nader's activism was not entirely without merit. Sure he f'uped and was over-zealous on specific things like the Corvair but he did some good in other area's.
Now - Joan Claybrook (a friend and co-worker with Nader) is an ENTIRELY different animal - :e15
PostPosted: Mon Jun 10, 2013 10:31 am
The Corvair turbo unit, and Carter YF single barrel carb were exactly the same as was used on the 1963 factory Oldsmobile turbo 215 cu/in all-aluminum V8 F-85's. Both the F85 and Corvair needed a good digital, tuned port EFI, REAL BAD. GM should have turbo'd the Buick Skylark instead of the F85, as the Buick engines had a different head, with a lot better combustion chambers than the F85 ever did. Buick did turbo their V6 version of this same engine later in life, on the GN (Grand National) and turbo Regal.
I do a lot of all aluminum Buick, and Rover 4.6 V8 engines, stroker cranks, big bore, Chevy rods, Crower cams, Rover EFI with Holley controller, Mustang nozzles, Edelbrock dual throttle bodies, and they work well. Too bad the Corvair engine didn't evolve, let alone survive.
Some 35 years ago, when I worked at Skunk Works for Duntov, there was an engine core pattern maker working at GM I met, and he was a Corvair lover. So much, that he used is expertise to build patterns for engine cases for the Corvair engines. His patterns were for a flat 8 cylinder version for the Corvair engine, still air cooled, and he had a buddy that was a machinist that did cranks and cams for him as well. Last I heard of i=him, he had only a handful of these things built, about 6, if memory serves, and none sold to outside persons. He did them for himself, nobody else. Only saw one running engine, on his engine stand, in his garage, once. NICE work, interesting concept.
PostPosted: Mon Jun 10, 2013 7:20 pm
PostPosted: Tue Jun 11, 2013 12:36 am
Z. A.-D., my former boss at G.M. Special Projects. One of the greatest people I ever worked with and was a great friend as well. Another was Carroll Selby.
PostPosted: Tue Jun 11, 2013 8:58 pm
I have a long history with Corvairs. I've had dune buggies, put Covair motors in VW buses, bugs and ghias. My last one was a 65 Corsa that I had the kitchen sink into. It is now in Arizona. I had tons of head work, titainium valve keepers and caps, aluminum roller rockers, large exhaust tubes inserted, intakes bored. I started with a Carter 625 cfm AFB and later went with a holley 750. I used a spearco water injection system. Saginaw 4-spd. 0.060 over bore Total seal piston & rings, 409 oil pump, shortened pistons and cylinders, reworked the squish area, balanced everything, lightened flywheel and some custom headers.
It did 158 mph and turned 8000 rpm. I did not find it dangerous at that speed. I used it for autocrossing, so I had a lot into the suspension as well. I will have to find some pictures and scan them.
Sorry, I can talk Corvairs for a very long time. I had no idea anyone here would care one bit about them.
75 H1
78 CB400II Hawk
78 KE175
