It is currently Thu May 01, 2025 1:22 pm
 Post subject: H2B build
PostPosted: Wed Jan 16, 2013 5:00 am
Hi there people. Just thought Id post a before/after shot of the H2B...
Ground up rebuild, back to the last nut and bolt. Backcut box, rebuilt crank etc. Stainless spokes and fasteners, all alloy vapour blasted...
All done bar a few niggly faults - Clutch is slipping like a mad thing, shoulda put a heavy duty one in :oops:, the carbs need dialling in and the ferkin crankcase oil feed line keeps going dry after a ride. Bleeds up ok but then airlocks (any ideas?) I have seen threads here about this prob and JB Weld and a Mity-Vac are on the way.....it'l get there in the end.
When it is finally dialled in there's a nice set of Higgsy spannies sitting right behind me as I type waiting to be fitted.
Anyways, hope you all likey.. :)
1982 Beige Austin Allegro
 Post subject: Re: H2B build
PostPosted: Wed Jan 16, 2013 6:22 am
What kind of oil did you put in the crankcase?
Did you align the dots on the clutch?
Properly adjust?
Are stat-o-seals fitted at the pump?
Best fit the Higgs before getting it dialed in or you'll have the job to do again.
PostPosted: Wed Jan 16, 2013 7:15 am
What type of oil in c/case? - 80W dino gear oil
Dots aligned - yes
Pretty sure its adjusted, got one of Ralfs actuators. Ill check
Looks like it had standard plates/springs. All checked out ok when I did a measure up tho..
Stats fitted everywhere apart from c/case banjos and oil inlet bottom seal. The lines off the bike atm, problem seems just like H2dudes problem with his H2B. Getting a Mity-Vac to do some tests as per your guides on the resource site. Probably best to test for leaks first?
Hmm, interesting about the spannies. I see your point, I just thought removing one variable from the equation was better. Ill contact Higgsy for some jetting baselines.
Cheers for the reply :)
PostPosted: Wed Jan 16, 2013 7:20 am
If I only knew what a Higgsy spannie is................ :eh:
PostPosted: Wed Jan 16, 2013 7:37 am
'Spannie' British slang for 'expansion chamber' - Higgs, British maker of quality spannies!! :crazy:
PostPosted: Wed Jan 16, 2013 7:38 am
Stainless chambers from UK.
http://www.higgspeed.com/
PostPosted: Wed Jan 16, 2013 7:41 am
A very fine example of Mr David Higgs stainless steel expansion pipes (Chambers) :mrgreen:
Beaten .. Arg
PostPosted: Wed Jan 16, 2013 7:43 am
Clutch shouldn't slip with stock engine and dino gear oil unless misadjusted actuator or worn plates.
Check valves are the next logical things to look at and don't forget the carb lines, too.
PostPosted: Wed Jan 16, 2013 7:47 am
Carb lines seem fine but will check with the mity
Daft question - just got me thinking, the 2 spacers on the clutch, one behind the basket and one behind the hub - which one goes where...Im sure I got them the right way round... paranoia settin in here lol
Think Ill pull the case since the pumps off.. :problem:
