It is currently Wed May 29, 2024 1:40 am
PostPosted: Wed Oct 24, 2012 5:57 pm
What is the best way to restore the colors on the switches? I would sure appreciate any suggestions on what type of paint colors, brushes or techniques that I should use. Monique is her name and she is a 1974 H2B 750 Mach IV.
PostPosted: Wed Oct 24, 2012 6:54 pm
On my S3 I stripped all the wiring out of the housings. I then had the housings powdered coated with satin black. The colors were restored with lacquer sticks in red, white, and yellow as required.
Rotortech
Indianapolis
1974 S3
PostPosted: Wed Oct 24, 2012 7:11 pm
Wow those are incredible. Thank you.
PostPosted: Thu Oct 25, 2012 2:11 am
That is GREAT work!, . . . . However, the switch markings are incorrect for your bike (or any model) - If yours is an S3 (U.S. Spec) Then I can assure you that :
Kill switch writing is ALL Red
The "P.O." IS not painted in at all on the U.S. bikes
The Turn signal arrows should be White
The "Pa" is also not painted in as the pass light feature wasn't used on U.S. models
Switch colour markings were same throughout the models each year, so S1b, S3, H1e, H2b would all be same colours, S1c, S3a, H1f, H2c all changed again
:geek:
PostPosted: Thu Oct 25, 2012 2:14 am
Yeah, but I like this better - they shoulda dunnit this way..............!! :lol:
PostPosted: Thu Oct 25, 2012 3:58 am
Where do you buy lacquer sticks? I hadn't heard of them before reading this post.
PostPosted: Thu Oct 25, 2012 12:09 pm
:geek:
R.B. - I would not want to debate the correct colors for any model triple. Looking back at my photos I noticed that most lettering was faded white. I looked at other controls and some repro items for color ideas. I just did what I thought would be reasonable.
As RODH2 said - I like the lettering better this way.
Rotortech
Indianapolis
1974 S3
PostPosted: Thu Oct 25, 2012 12:10 pm
Thanks monique - they look just fine on the bike.
Rotortech
Indianapolis
1974 S3
PostPosted: Thu Oct 25, 2012 12:16 pm
Mike - I have lost track of where I got them. I know you can order individual colors from Amazon (store front for Micro-Tools). They are only a couple of dollars each and will last you a long time.
They are Markal Lacquer Sticks. http://www.amazon.com/Markal-Lacquer-Stik-Paintstick-White/dp/B002BY8HKS/ref=sr_1_2?s=hi&ie=UTF8&qid=1351184563&sr=1-2&keywords=lacquer+sticks
Rotortech
Indianapolis
1974 S3
PostPosted: Thu Oct 25, 2012 7:24 pm
thanks for the info!
