It is currently Mon May 05, 2025 5:27 am
 Post subject: Throttle cable issue
PostPosted: Wed May 16, 2012 8:37 pm
Hey gang, back to work on the H1.
What is the correct routing for the throttle cable? I have it going down the right side of the frame with the shortest cable to the middle carb, the longest to the left carb and the next longest to the right carb. Is this right? I am having a hard time getting the left carb slide to come all the way down.
Thanks,
Jim
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
 Post subject: Re: Throttle cable issue
PostPosted: Sat May 19, 2012 11:10 am
Anybody? I didn't have this problem before I took the cables off to clean them up and lube them. Are they all supposed to be different lengths?
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Sat May 19, 2012 11:16 am
Your routing sounds correct.
Is the idle rod bent?
PostPosted: Sat May 19, 2012 11:32 am
Did you open the 4 way junction? The cables can get crossed inside here.
J
PostPosted: Sat May 19, 2012 11:43 am
I thought everything came down the left side of the frame.... :?:
PostPosted: Sat May 19, 2012 12:04 pm
Only if you are facing the front of the bike :P
PostPosted: Sat May 19, 2012 12:08 pm
Ah ok........ :clap:
PostPosted: Sat May 19, 2012 12:39 pm
Those of us that have lower/shorter handlebars often route the cables to the opposite side of the tank (from the control) to use up excess cable lengths! ;)
J
PostPosted: Sat May 19, 2012 1:56 pm
J
I did so I'll check that.
I have the superbike bars but I had them before I had this problem...
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
