It is currently Mon May 05, 2025 12:18 am
 Post subject: carb questions ?
PostPosted: Sat May 19, 2012 10:51 am
Got the 75 h2 running now but can't get it to idle and it stumbles at low speed under 2k or so . Carbs are stock with 110 mains and everything else stock but pod filters . If choke is on it runs good but if I let off stumbling starts and no idle, any thoughts ? Thanks
 Post subject: Re: carb questions ?
PostPosted: Sat May 19, 2012 11:03 am
You need richer slides. JA can modify yours.
PostPosted: Sat May 19, 2012 11:42 am
Sounds like it may be blocked pilot jets.....
PostPosted: Sat May 19, 2012 11:51 am
I've gone thru the carbs 3x now and everything was clear , may do it again I guess getting tired of it though . Wish I had kept my 73 h2 now never had a problem in 10yrs of owning it
PostPosted: Sat May 19, 2012 11:54 am
Did you rremove the heedle jets, and do a visual on the pilots to see if they were clear? and of course set the floats?
PostPosted: Sat May 19, 2012 12:54 pm
visual done on all jets, no on the floats have to look into how to set them, thanks
