It is currently Sat May 03, 2025 10:13 am
PostPosted: Mon Apr 09, 2012 4:04 pm
the threads at the intake from the oil tank are stripped. Looking for an oil pump for a 1974 H1. Any out there or any suggestions to repair the one i have?
PostPosted: Mon Apr 09, 2012 4:20 pm
just fix it
PostPosted: Mon Apr 09, 2012 5:27 pm
I had the same problem with my pump.... You can heli-coil the pump with a M6 x 1
Use stato seals as well, they seal with less torque then aluminum crush washers.
PostPosted: Mon Apr 09, 2012 6:42 pm
If you take the little end plate off you can vacuum out the chips from drilling and tapping for the Helicoil as you make them. Just don't leave any behind.
PostPosted: Tue Apr 10, 2012 6:21 am
Thanks for the idea's. Helicoil it is!!!
PostPosted: Tue Apr 10, 2012 7:55 am
Boy do they... yesterday I cleaned and adjusted my check valves, and I had Stat-O-Seals on the banjo bolt I used to connect the oil lines to my air regulator. They sealed fine when just finger tight.
Of course in a triple, they need to be a little tighter than that so they don't vibrate loose, and I safety wired mine.
PostPosted: Tue Apr 10, 2012 8:30 am
I used a helicoil on my oil pump, with new original crush washers. No Leaks so far. From a what I have read stato seals seem to be better, particularly if you are reusing.
Steve
PostPosted: Tue Apr 10, 2012 8:36 am
It's a fine line between getting the aluminum washers to seal and stripping threads. The only trouble with Stat-O-Seals I know of is that on the pump inlet, the rubber seal on the one that goes against the pump doesn't contact anything, so it will ooze oil unless you use a little sealer there, or better, cut a gasket instead.
PostPosted: Sun Apr 15, 2012 8:08 am
to all who gave suggestions, thank you. I did the heli-coil on the oil pump and every thing worked out fine. Used the stat o seals and no leaks.
PostPosted: Sun May 06, 2012 10:19 pm
Any one got a link for the stato seals. I have noticed my oil pump still leaks after about a week, even with new washers. I am going to convert to stato seals, but could not find them on ebay.
Steve
