It is currently Fri May 02, 2025 9:03 am
PostPosted: Tue Feb 14, 2012 12:55 pm
just a thought could i use a 520 seris chain on 530 sprockets if i was to skim the thickness down to suit as i have reasonable sprockets ,no chain and i think i need extra clearance for the new clutch actuator.
thanks mark
PostPosted: Tue Feb 14, 2012 1:05 pm
Be aware the front sprocket is as hard as the "Hubs of h#ll". You'll have the side shape of the teeth to duplicate too after thinning the sprocket...
J
PostPosted: Tue Feb 14, 2012 6:29 pm
just get 520 sprockets.....
PostPosted: Tue Feb 14, 2012 7:31 pm
We run 520 on the drag bike with a 520 front sprocket and a narrowed 530 on the rear as they are more readily available. The tooth pitch is the same just needs to be narrowed
PostPosted: Tue Feb 14, 2012 7:54 pm
i think i will follow the advise and at least get the small sprocket in the 520 and experiment with the rear.
there is a set (sprockets only)on fleabay but at $125 its a bit spendy.
thanks mark
PostPosted: Tue Feb 14, 2012 10:01 pm
I did a 520 conversion on my H2, but im not sure how close everything lines up from front to rear sprockets - I didnt check before I started the restore project -the motor is not in. But I still have the original RK 520 chain that has a few kinks in it - from my understanding thats usually from misalignment either from the chain adjuster or its just not lining up - side pressure was put on the plates or rollers.
The right sprocket is a 520 for the H2...
...the 520 and 530 chain/sprocket together.
I thought this was pretty neat a laser check alignment tool - but pricey.
http://www.youtube.com/watch?v=9NC8p5hbJSA
Or the cheap version
http://shop.jcspecialty.net/SPROCKET-LA ... 9LAZER.htm
PostPosted: Tue Feb 14, 2012 10:45 pm
great photos joe, a real help, and i like the cheapo laser , i think i will treat myself with the money i save by skiming the rear sprocket. :thumbup:
PostPosted: Tue Feb 14, 2012 11:04 pm
Probably obvious, but just skim the tooth area..... :thumbup:
PostPosted: Wed Feb 15, 2012 5:19 pm
A good deal can be had here:
http://shop.pbisprockets.com/category.sc?categoryId=31
Selecting the 520 option actually saves you $$$$! A sprocket pn (amongst several) that fits the front of the triples is the #754 series. It has a built in spacer too.
J
PostPosted: Wed Feb 15, 2012 8:41 pm
thanks ja and looney i ordering some from PBI, cheap enough to not bother with.
thanks mark
