It is currently Thu May 01, 2025 1:45 pm
 Post subject: Kawasaki A7 pistons
PostPosted: Mon Jan 02, 2012 11:51 am
Hi, still looking for kawa A7 63mm pistons , Wiseco part number 147-p4"s (also 147-p6's(63.5)), or kawa part number 13027-024. also could use rod kits for A7's thanks Tom
 Post subject: Re: Kawasaki A7 pistons
PostPosted: Mon Jan 02, 2012 11:47 pm
Might have John Aylor ask Hurley Wilvert what he did last year for rod kits for the A1/A7's, I seem to remember he modified H series rod kits to work.
If, for any reason, you don't get comnnected with HTW, let me know and I'll ask him for you.
One of the early mods for a bigger H1 was to use A7 pistons in it, only needed boring. I remember that there were some H seeries pistons that interchanged with not so much work into some of the older Jet Ski engines as well, and, maybe, maybe the Jet Ski rod kits are close, workable as well.
MIght also look into F3 pistons/rings as well, they are still available, and if I remember, close to A7 sizing.
Just a couple of thoughts for you to investigate/consider.
PostPosted: Wed Jan 11, 2012 9:20 am
I'll have a look tonight
have a spare set with rings not sure which size they are
PostPosted: Tue Jan 24, 2012 1:09 pm
Guys,
Don't forget that Wossner Pistons can make a small run custom order with a minimum order of 4 pistons of the same bore, if interested please call us at 714 369 8879
Thanks,
John
PostPosted: Thu Jan 26, 2012 10:14 am
Sorry, only got std size
PostPosted: Thu Jan 26, 2012 6:31 pm
thanks for looking, I now have enough of the wiseco 147- P4's (63.0mm A7 pistons,thanks Steve B.) but would love to find a pair of 147- P6's (63.5mm A7 pistons). thanks Tom
