It is currently Thu May 01, 2025 1:52 pm
 Post subject: S2A points cam
PostPosted: Fri Nov 18, 2011 6:53 pm
Looking for a points cam for a '73 S2A. The pin on mine has been snapped off. Check it out:
Terry
 Post subject: Re: S2A points cam
PostPosted: Fri Nov 18, 2011 10:31 pm
Ive got a 72 S2 points cam, that should be the same :idea:
PostPosted: Sat Nov 19, 2011 8:41 am
Just checked and the P/N are the same. What do you want for it?
Terry
PostPosted: Sat Nov 19, 2011 10:53 am
pm sent
PostPosted: Thu Nov 24, 2011 9:06 am
I'm still looking for a points cam for an S2A. Member "Jackman" was kind enough to work one loose off of his parts bike, but it's a bit rusty.
Anyone else have a decent one?
Thanks again Jack!
Terry
PostPosted: Thu Nov 24, 2011 10:38 am
Terry I scrub the cam a little more and attempted a close up shot it looks better than it did :o , the area above the cam lobe has the most pitting but is that area a function part.
Could this be a usable part?
PostPosted: Thu Nov 24, 2011 10:44 am
PostPosted: Fri Nov 25, 2011 9:18 am
pm sent
PostPosted: Fri Nov 25, 2011 9:44 am
Confirmed my S2 points cam in previous pic when compared to the same part in my S3 its toast, contact area above the cam lobe is all pitted bad cam it self also pitted.
PostPosted: Fri Nov 25, 2011 1:11 pm
You can put JB Weld in those pits and polish it out to be like new.
You can also drill out the broken locating pin and replace it.
