ALTERED IMAGE wrote:
Looking at your mirrors...are you happy with the view?
If so, which brand?
getting restless here
p.s.
speedo is wacky
cliff
The mirrors are OK i guess (pictures below), but could do with a little longer stems. Easy enough to make. I just haven't gotten around to it.
My speedo is spot on but it falls to zero in tunnels because it is a GPS speedo (SpeedHut).
There's also another slightly annoying thing with the GPS speedo and that is the needle won't keep up with maximum acceleration, especially in 1'st, 2'nd and 3'rd. There may also be a slight lagging behind in 4'th. I guess it has to do with the maximum puls frequency that can be sendt to the needle stepper motor.
If you look at the snapshots below from the video. A split second
before i shift from 4'th to 5'th the tach shows 9600 rpm and the speedo shows a tad less than 180 km/h. A split second
after the shift the tach shows 8200 rpm and the speedo has caught up and shows 180 km/h. There probably haven't been much acceleration during the shift.
I have the shift light set to 9500 rpm.
P.K.
