It is currently Mon May 05, 2025 9:43 pm
 Post subject: VM 28 carbs
PostPosted: Sun Nov 13, 2011 4:43 pm
Hi all
i went out for a short 5 miles ride to test out the new crank.
about 3 miles into the ride came to a stop light went to take off the bike fall flat on it's face i hade to ring it's neck to get going i made it home let the bike cool off and checked the carb caps and the middle one was loose.I am looking for a way to help keep the caps tight on these carbs i was thinking clear silicone.
Chris
 Post subject: Re: VM 28 carbs
PostPosted: Sun Nov 13, 2011 4:59 pm
Do you have the rubber gaskets in the caps?
PostPosted: Sun Nov 13, 2011 5:20 pm
Yes, check for those, and there is no need for goop if the tops are tight and have the gasket.
PostPosted: Mon Nov 14, 2011 3:47 pm
Yes on the rubber gaskets
PostPosted: Mon Nov 14, 2011 4:10 pm
I've never had a carb top unscrew itself, strange.
