It is currently Wed Apr 30, 2025 12:04 pm
 Post subject: Re: Carb Question
PostPosted: Fri Feb 02, 2024 1:46 pm
The gasket is there for a reason.... I've seen high revs on Suzukis and Kaws when loose cap was the cause.... nothing to do with cable.
PostPosted: Sat Feb 03, 2024 8:19 am
Carb sure looks like a H1 with tophat and cap with seal needed.
cliff
PostPosted: Sat Feb 10, 2024 9:30 am
Hi Cliff
I agree that the notch in the carb body is the same as an H1 carb.
I confirmed that my carbs are all stamped S2U-0 which is correct for an S2A
PostPosted: Sat Feb 10, 2024 3:42 pm
Seal IS for anti-rotation that prevents cap loosening.
It also minimizes air leak. Along with the tight fitting throttle cable ferrule.
No vacuum? It is trying to equalize vac under the slides to air pressure. So NO.
It does effect mixture.
cliff
PostPosted: Fri Apr 12, 2024 10:40 pm
The manual does not show a gasket for the cap, does someone know the part number or is it part of the cap? I guess I should clarify it's for an H2B, thanks
PostPosted: Sat Apr 13, 2024 6:05 am
I can't find a part# or source but you could make one.
Use an old innertube and cut to fit snug inside of cap... a ring about 3/16 wide.
PostPosted: Sat Apr 13, 2024 1:08 pm
Thanks for looking
PostPosted: Sun Apr 14, 2024 1:01 pm
0120raptor wrote:
mraxl wrote:
0120raptor wrote:
The slot is at atmospheric pressure so it will never leak air. It`s not under any engine vacuum. You could unscrew the top completely and it won`t make any difference.
I disagree! Slot is not a problem but a loose cap will make it rev to the moon. Been there- done that.
I`m not suggesting remove the cap and run the engine. I mean you could THERORETICALLY remove the cap and assuming the slides don`t move the engine won`t suck in any more air.
Underside of Cut Away (CA) does not have same air pressure than atmosphere.
Especially at part throttles.
Air leaks at low throttle from the jet needle hole/e-clip/cable end.
cliff
PostPosted: Sun Apr 14, 2024 3:28 pm
Two different types of carb tops
One has an insert for the inner cable holder, and idle shaft, and a setting ring to hold it all in place
The other is as you show, screw on, one piece.
Both use a thin rubber "gasket", not sealed.
If that area was sealed, the slide wouldn't be able to rise in the body.
PostPosted: Sun Mar 23, 2025 9:28 am
It's never sealed.
Pressure on top of CA is not the same as bottom of CA.
The rubber seal is for anti-rotation and sealing top of CA from atmospheric pressure, although not really important except for highly tuned carbs for like engines.
So pressure on top is equalized to pressure on bottom via cable slot and a little by the JN top.
