It is currently Fri May 02, 2025 7:35 am
 Post subject: Before or after boring?
PostPosted: Sun Jun 12, 2022 8:49 pm
Should the cylinders on an H1 be bored out to new size before or after bead blasting?
PostPosted: Sun Jun 12, 2022 8:54 pm
My customers preference has historically been before.
PostPosted: Mon Jun 13, 2022 4:39 am
Just wondering why bead blast after bore/hone?
I see no logic.
cliff
PostPosted: Mon Jun 13, 2022 9:27 am
LAST operations are bore/hone
First, clean, bead blast, close pores in the aluminum with Brillo pad.
PostPosted: Mon Jun 13, 2022 10:25 am
I second H2RTuner. I do not like to risk any particles left behind.
PostPosted: Mon Jun 13, 2022 7:34 pm
Thank you to all for replies.
Tim: Sent you a pm
PostPosted: Tue Jun 14, 2022 9:28 am
Clarification on the Brillo pad. All bead blasting opens the pores of the aluminum, allowing capture of dirt, grime, oils, grease, discoloring the aluminum. The Brillo pad closes those open pores, so adversive stuff doesn't stick, and the aluminum goes back to looking as new.
