It is currently Wed Apr 30, 2025 7:39 pm
Post new topic Reply to topic  [ 119 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12  Next
 Post subject: Re: J's H1D Restoration
PostPosted: Sun Jan 16, 2022 7:04 pm
There was not a "lot" of rebound-damping in the early forks and shocks, the forks worked pretty well considering, imo, but the rear shocks not so much....... :think:
PostPosted: Sat Feb 05, 2022 2:24 pm
I was planning to get some brass swing arm bushings installed today but the old steel bushings are resisting all of my efforts to drive then out. Any tips or tricks to remove them?
PostPosted: Sat Feb 05, 2022 2:49 pm
My H2 had the green fiber bushings and I had to drive them out with a steel bar and a big hammer, and even then they came out in pieces.
PostPosted: Sat Feb 05, 2022 2:59 pm
Will the long center sleeve come out with the bushings installed? Seems like it ought to but mine is being stubborn.
PostPosted: Sun Feb 06, 2022 1:58 pm
Anybody? :?:
PostPosted: Sun Feb 06, 2022 2:56 pm
It's been ten years since I did mine, but as I remember you have to push the center spacer over to one side so you can get a drift on the far bushing and whack it.
Page 55 of the Kaw shop manual shows what I mean. http://kawatriple.com/manuals/hseries/page_067.pdf
PostPosted: Sun Feb 06, 2022 11:27 pm
Jim is correct, reach in with a long punch(using the punch to push the sleeve to the side)and drive them out. You don't have a lot of surface to grab with the punch and a lot of times it will rip a piece of the bushing off so you can't hammer on that spot again. Sometimes they come out easy and sometimes very hard and you have to use a little heat.
PostPosted: Mon Feb 07, 2022 11:57 am
Thanks guys for the reply.
Yes, it looks like I'm going to need to apply some heat to get the bushings out. They're actually in service limits. Wondering if the juice is worth the squeeze in this case.
PostPosted: Sun Feb 20, 2022 2:47 pm
Is it possible to obtain a replacement steering lock key?
Looks like part number 277
Thanks for any replies!
PostPosted: Sun Feb 20, 2022 3:20 pm
JohnnyO here on the board is now doing keys.
