It is currently Thu May 01, 2025 8:06 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2, 3  Next
PostPosted: Wed Sep 11, 2019 5:34 am
It turns out the injection pump that came with my H2 is actually off an S series bike. It leaks anyway. Ideally I’m looking for an H2 pump for my ‘72 H2, but I’m told an H1 pump will work also.
Thanks
Mark
Obstreperous stink wheels!
1975 Yamaha RD350
1975 Yamaha TZ750
1980 Moto Guzzi SP1000
2019 Triumph T100
PostPosted: Tue Sep 17, 2019 2:29 pm
Here's one: https://www.ebay.com/itm/1973-KAWASAKI- ... SwUjRdfmAH
PostPosted: Tue Sep 17, 2019 7:17 pm
Hawaii-Mike wrote:
Monkey Claw...just saying :shock:
PostPosted: Tue Sep 17, 2019 8:49 pm
I have bought from him and have never had any problems. But some people have. Needless to say the opening bid is very reasonable.
PostPosted: Tue Sep 17, 2019 10:09 pm
JayDav wrote:
Mach 4 Motors
PostPosted: Wed Sep 18, 2019 8:02 pm
https://www.ebay.com/itm/1973-Kawasaki- ... Swm0ldgrYf
PostPosted: Wed Sep 18, 2019 9:10 pm
Tim Steele wrote:
https://www.ebay.com/itm/1973-Kawasaki-H2-750-Complete-Oil-Injection-Pump-Banjo-All/254363785167?hash=item3b394357cf:g:tBwAAOSwm0ldgrYf
Good link, good price, but it seems pretty dumb to just cut the oil lines!
PostPosted: Thu Sep 19, 2019 12:37 am
I agree
PostPosted: Thu Sep 19, 2019 10:48 am
On adjustment of this particular pump, when we used to do run setup at KMC, we set the oil pump last thing, after timing, then carb float levels, balance. If you look at the baile, the cable wheel, there is a line, and two dots. Engine off, wide open throttle, last dot on the wheel to the line on the post, worked best with the non-synthetic oils of those days. Oil line relief valve blow off we always set to 4.6 psi.
PostPosted: Thu Sep 19, 2019 11:39 am
It's not always easy to find your 8mm socket when you need it.. :lol:
