It is currently Thu May 01, 2025 1:26 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Wed Jun 29, 2016 2:28 pm
Thanks Jim!
PostPosted: Wed Jun 29, 2016 5:42 pm
Nice bike, and fantastic work, Tim.
I like a bike that has usable brakes, and I don't subscribe to the "one is enough" mind set, I LIKE BIG BRAKES, ones set up to work the right way, not lock the front wheel up with a single finger pull. that setup looks just right for that size bike.
I can't see that well, did you add one of those calipers to the rear brake? Looks like the stock RZ one. Of course, I never use the rear brake unless it is dire staits, but nice to know it was there, as well.
PostPosted: Wed Jun 29, 2016 7:16 pm
Stock RZ on the rear... I don't use much rear brake either...thanks!!
PostPosted: Wed Jul 06, 2016 6:11 pm
Imagepost img
NOS aftermarket lever installed. There was a slight clearance issue at the brake lite switch, solved with a cut off vacuum plug.
PostPosted: Mon Sep 19, 2016 2:45 pm
just saw this close up. id suggest heat shrink insulating the bare plugs on the switch. if the hot one happens to come loose it will short and blow a fuse quick. + will look a lot better. just my .02
PostPosted: Mon Sep 19, 2016 10:59 pm
OK will do and thanks....
