It is currently Thu May 23, 2024 1:03 pm
Post new topic Reply to topic  [ 185 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 19  Next
 Post subject: Re: H1, 1970
PostPosted: Sun Apr 24, 2016 9:09 am
Bought a brand new red '70 H1 in....... 1970, (sorry!) :lol: Raced it in production racing in Australia, which meant EXACTLY showroom condition, remove the lights and put on no. plates and go racing. Won a few races, in spite of the drum front brake, (which you can get to work...). Swapped for a H2 in '72, which is where my heart is, but had the full H1 experience. In its day, the performance, and, yes, the handling, were at the front of the grid..... so for all the stories about its evil handling, etc. you were still able to look behind you to see where the others were! Throw the centre stand away, and start grinding on the mufflers for ground clearance.......! :lol: ... :thumbup:
PostPosted: Sun Apr 24, 2016 9:58 am
When I use tapered steering bearings it usually changes the fork ear
Gap between fork clamps . You may have to shim so the ears won't be loose .
http://davestriples.com/
PostPosted: Sun Apr 24, 2016 10:10 am
Yep, with the tapers, just add an o-ring to each fork tube, so the ears don't rattle.
PostPosted: Sun Apr 24, 2016 2:31 pm
Thanks Dave and Ja-Moo :)
Peter says:
Keep the revs up !
Bikes:
H1 Candy Red, 1970
Moto Guzzi Daytona 1000, 1992
PostPosted: Tue May 03, 2016 3:49 pm
Ok - let's get it on...
As I had no access to tools which can press in the roller-bearing race, I had to rely on the old trick:
I borrowed a little space in the wife's freezer, threw in the races and gently heated up the steering head pipe to approx. 40-50 degrees celsius.
The race will shrink a little, and the steering head pipe will expand a little. Enough to make you fit the race with only some gentle blows from a mallet.
Of course you must not hit the revolving part of the bearing. Only hit the race, and to do this carefully, you must hit the top egde with something which has almost the exact same diameter - like the old race, or a socket from a socket wrench set:
Job done:
Somewhat later:
Front- and rear fender are Stainless (in contradiction to Honda for instance)...
... and they were very nice, so it was an easy job to clean and polish them. I sanded the downside and applied 2-3 coats of silver.
Nylon lock nuts are of course not original spec., but I don't wanna tighten nuts on some dark secondary road :)
Shocks are repro's from Diablo Cycles, but grip, rear fender stay, license plate bracket and tail lamp are the original ones, and hasn't even been rechromed:
Starting to look a LITTLE like something:
- notice the correct Kawasaki bolts :geek:
Original Mitsubishi voltage regulator in nice condition with original wires. Just cleaned and polished a bit by hand:
That's all for today folks...
Peter says:
Keep the revs up !
Bikes:
H1 Candy Red, 1970
PostPosted: Wed May 11, 2016 6:06 pm
Updated
Peter says:
Keep the revs up !
Bikes:
H1 Candy Red, 1970
PostPosted: Thu May 12, 2016 9:52 am
Looks great...keep going!
PostPosted: Thu May 12, 2016 4:20 pm
Thanks Zambia - I will!
But it's sometimes difficult to stay clear of worklife, lawn moving, family ans so on ;)
Peter says:
Keep the revs up !
Bikes:
H1 Candy Red, 1970
PostPosted: Sun Jun 12, 2016 3:27 pm
Battery box:
The first parts starts arriving (this will continue for a looong time, I'm afraid):
A french guy (Patrick Bras) makes some nice bolts and fasteners:
The mechanical steering damper which came with the bike, was not the original type, and I searched for long for an original replacement. I fininally bought one from from Sweden, but it was slightly damaged, so I had to think out a way of fixing it:
Sacrificing the wrong steering damper (made of the same material) I fabricated some grain:
The grain was mixed with two-component Epoxy glue
and applied to the right stering damper wheel. I just had to make a stop, preventing the glue from slipping down:
The finished damper, with all parts:
Finished - (cotter pin is missing):
Had to source a new steering lock (NOS) as this was missing too. These parts are not exactly cheap ;)
Peter says:
Keep the revs up !
Bikes:
H1 Candy Red, 1970
PostPosted: Sun Jun 12, 2016 6:30 pm
Very nice job with the epoxy!
