It is currently Sat May 03, 2025 11:29 am
 Post subject: H2b oil pump
PostPosted: Tue Apr 19, 2016 4:37 pm
anyone have a spare H2B oil pump? yep, I striped the inlet banjo bolt threads
 Post subject: Re: H2b oil pump
PostPosted: Tue Apr 19, 2016 5:24 pm
If you don't Healy coil then of some type. I have them some nice ones.
PostPosted: Tue Apr 19, 2016 9:55 pm
Hoozier1 I have a couple of spares. Will send you a pm with pics. I don't remember how I ended up with two extras, just accumulated stuff over time.
Mike
PostPosted: Tue Apr 19, 2016 11:51 pm
There are people on this board that offer Heli-Coil repairs to those specific oil pump threads.
PostPosted: Wed Apr 20, 2016 2:10 pm
I thought about helicoil but didn't think they made them that small.
I know a gut that is a machinist, maybe I should give him a call
PostPosted: Wed Apr 20, 2016 5:20 pm
I'm a machinist with well over 35 years experience and have installed literally thousands of helicoils. I can fix that for you correctly.
viewtopic.php?f=25&t=3715
Jeff
PostPosted: Thu Apr 21, 2016 11:10 am
Jeff
Well, looks like your the man! I got your e-mail. looks like this the route to go.
I have a helicoil question. I have stripped threads for exhaust stud. I have the helicoil kit.
should I use somesort of loctite on that insert? epoxy?
PostPosted: Thu Apr 21, 2016 11:27 am
Jeff is the guy I emailed you about Tuesday.
PostPosted: Thu Apr 21, 2016 9:30 pm
Jeff
There are two types of heli coil inserts, free running and locking. Properly installed, either would be fine for the exhaust stud threads. ( the locking type are designed for thru holes ). Just make sure you drill the correct size hole and tap it square.
PostPosted: Wed May 25, 2016 9:54 am
old coils let go - I was in a crunch with a pending trip - and JRD (Jeff) came to the rescue! :thumbup:
As always the work is stellar !!!!!!!! :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
