It is currently Thu May 01, 2025 12:19 pm
 Post subject: Screws with numbers
PostPosted: Tue Mar 15, 2016 11:31 am
Hi,
does anybody know exactly wich screws on which triples have numbers or were I can find this information, specifically H1 and H2.
Also were Kawasaki market with yellow paint screws and so on when they sold these bikes new.
All the best and many thanks from Germany
Ralf
 Post subject: Re: Screws with numbers
PostPosted: Tue Mar 15, 2016 12:34 pm
yellow marks on screws: 1974 model year
My H2B had them when I got it at the end of the 20th century
but neither my H2A or my S2A had them or my first H2A on the 70s :mrgreen:
PostPosted: Tue Mar 15, 2016 2:15 pm
Ralph, the yellow paint was used on the brake and steering components to show if they had been loosened or removed after the bike left the factory(I would guess for liability purpose). The H2 and the H2A had almost all number 4 marked bolts with some 7's. The only way I get them back in the right spot is to take lots of pics when I take the bike apart and bag and tag everything, as I'm sure you do. I do not know of a complete list as to where they go but in most cases you can look up the part number and then look that up in Mraxl's oem parts list. Most of the time they have a picture of the screw(bolt). If there is a specific bolt or two you can't place maybe I can help.
PostPosted: Tue Mar 15, 2016 3:43 pm
The little 10mm ones with the raised "7" are hard to find...and expensive. But since they hold the brake cylinder on...you can't hope to get away without using them..
PostPosted: Tue Mar 15, 2016 4:44 pm
Here are some with raised numbers... there may be others:
"7"
http://3cyl.com/mraxl/partid/list2/110N0625.jpg
http://3cyl.com/mraxl/partid/list2/112G0618.jpg
"4"
http://3cyl.com/mraxl/partid/list2/110N0820.jpg
http://3cyl.com/mraxl/partid/list2/110N0825.jpg
PostPosted: Wed Mar 16, 2016 10:23 pm
What is the significance of the number 7?
For Honda's it was the number 8.
PostPosted: Thu Mar 17, 2016 6:31 am
For The Beatles it was Number Nine! :lol:
PostPosted: Thu Mar 17, 2016 6:50 am
Relates to the tensile hardness or shear strength, I think..... (hey, that's close, and no-one else answered!!) :D
PostPosted: Thu Mar 17, 2016 7:20 am
The markings are likely based on a now obsolete Japanese (JIS) designation system. Grades such as 4T, 7T, and 9T indicate the nominal tensile strength in kgf/mm2 x 100, which means that in MPa the values are 392, 686, and 883 respectively.
PostPosted: Thu Mar 17, 2016 4:43 pm
Hi,
my problem is that I'm not sure where these screws were mounted from Kawasaki. Because for me it's not clear how to identify them in the parts book.
I can check the numbers I got now, but are these all?
I remember that RB restored H2C with the yellow marking on some places longer time ago.
Perhaps RB has some documents which can help. I try to get in touch with him,
All the best from Germany
Ralf
