It is currently Thu May 01, 2025 7:53 am
PostPosted: Wed Jan 20, 2016 8:10 pm
These items are what I have found to be different so far, what am I missing?
Frame
Fuel tank
Side Cover "750" Emblems
Seat
Fuel Cock (Bezel)
Rear Foot Rests
Colors
Decals
3 H2's, all stock
H2B, converted to H2C
75 Paint & Decals by Brian H
75 Euro Seat by Tony O'Connor
PostPosted: Wed Jan 20, 2016 8:21 pm
speedo & tach faces
PostPosted: Wed Jan 20, 2016 8:31 pm
seat trim is shorter on the C.........and the stickers under the seat
I think one has a single helmet hook........my B frame has two........again, not sure
engine side covers I believe ( :?: ) on the C............shift pattern on left side.........1.6L of oil on the right
I think maybe the swingarm length, not sure on that.........thought some slight length difference maybe
I have a B with the C tank, seat, engine covers..........seemed somebody went thru some hassle
Where is RB when you need him.........he would know
Look at the MRAXL Triple Resource.........Photo ID pictures.........that shows a lot
THX Phil :thumbup:
PostPosted: Thu Jan 21, 2016 4:12 am
coils (black ones) on C
rear brake pedal electric wire for the stop light
control right side is different between B and C
the speedo is different between B and C 10 to 10 marks on B , 5 to 5 marks on C but with euro speedo the 5 to 5 marks with supposes to be C came early my B H2F 32*** has already got a 5 to 5
shift pattern was already on B
noticed also later B have already got the clutch cover with 1.6 liter which supposes to be C.
Swingarm has the same length on B and C.
frame is the same excepted B has only one bracket each side to fit the rear tank rubber and C has two brackets each side to fit the rear tank rubber whatsover the tank is B or C.
PostPosted: Thu Jan 21, 2016 11:31 am
Switchgear :shh:
PostPosted: Fri Jan 22, 2016 12:01 am
RH exhaust mounting plate
PostPosted: Fri Jan 22, 2016 4:27 am
oh yes I forgot this: one bracket on B, two brackets or a kind of double one in 2 parts on C.
Thanks Brian ;)
PostPosted: Fri Jan 22, 2016 3:34 pm
I'll bide my time on this One . . . But swing arm pivot and Rear Axle bolt for starters ;)
