It is currently Fri May 02, 2025 9:29 am
 Post subject: 1973 H2A rear pegs
PostPosted: Mon Nov 02, 2015 11:56 am
What color were the rear pegs on the H2A? When I stripped the ones I'm working on they looked like the same Army green looking color that the lock washer for the front brake lever bolt is. Or were they natural finish?
 Post subject: Re: 1973 H2A rear pegs
PostPosted: Mon Nov 02, 2015 2:41 pm
the brackets are olive drab zinc
PostPosted: Mon Nov 02, 2015 3:51 pm
Thanks!
PostPosted: Mon Nov 02, 2015 5:47 pm
:think:
PostPosted: Mon Nov 02, 2015 6:26 pm
This one.
I have some zinc-chromate primer I used to use on the inside of aircraft panels that should be about the same shade of green.
PostPosted: Mon Nov 02, 2015 6:29 pm
R.B. wrote:
:think:
Did you get the pictures of the KZ650?
PostPosted: Wed Nov 04, 2015 6:35 pm
GUTS wrote:
This one.
Never EVER seen one in Passivate before :shock: - They are usually flashed chrome :think:
I'm in the U.K. at the moment so things are megga stressy tidying up loose ends . . . communication for all things and message boards are a low priority . . . However, I'm picking your bodywork up in the morning and it should be in a container heading of the U.S. in the next 36 hours 8-)
PostPosted: Wed Nov 04, 2015 7:17 pm
R.B. wrote:
GUTS wrote:
This one.
That one is from the H2A I'm working on and the one that came off my Z1 is green too(so was the nos replacement).
:o , I better light a fire under my but then. :D
