If the tappets, shims and retainers are still stock, and haven't been converted to KZ650/750 shim under buckets, they'd be 29 mm diameter, same as Yamaha. Even my Toyota 2.5l 4valve Yamaha V6 uses them.
I use a dwell meter and timing light on the points, 192 degrees, on the 8 cylinder scale, 24 degrees. I then time it to the last full advance mark. From then on, as long as you do not move the timing plates, restoring the point gap with the timing light brings the dwell and timing right back.
Best electronic ignition, Dyna S, stock coils good NGK or stock resistor caps, B8ES spark plugs. No Iriduim plugs needed, nor wanted, better is B8EV Gold Palladium.
Cam chain tensioner is simple, cold engine, turn to 1/4 TDC, let the lock nut and bolt loose, tap the tensioner a couple of times, tighten the bolt and nut. Later model KZ1000 self adjusting ramp and ball bearing tensioner works better, no adjustment. Cross tensioner is icing on the cake.
If you ever find the need to pull the exhaust am out of the head, remove the tach drive gear and its holder first, put it back last. This is the single biggest reason we sold tach drive gears, broken when they didn't match up on cam reassembly, especially on shim under bucket exhaust cams.
We also used to turn the cam bore end caps 180 degrees, and position the lip inside the head, not outside, then we also used Three-Bond 1104, no1w 1194, to seal them into the bores.
20W-50 oil works best (I always used Castrol GTX), 10W-40 is too light, NO synthetics.
For the carb issues, adjuster problems, we were close to American Turbo-Pak, and bought all those 1978 Z1R carbs new, never run, that they took off when they turbo'd those things, 100 bucks later, and it was golden, they worked better than the stock carbs did, real world balance adjusters too, less money thn a set of 29 smooth bores.
Funny how all this stuff comes back like it was yesterday...oh, wait, I did one of these for a fellow in Reno, after the dealer there did it very badly, just last week.
