It is currently Fri May 02, 2025 11:17 am
 Post subject: 1975 KH100 for sale
PostPosted: Fri Aug 28, 2015 2:05 pm
Time to make some room in the garage so I can work on the kh400!
Up for sale is a Classic 1975 Kawasaki KH100 in great shape- Candy Royal Blue. When I purchased it, the original owner had it running pre-mix; I promptly replaced the oil pump and have been running it 'proper' since then. I had it registered here in CT so it has a clean registration. CT doesn't do titles for vehicles over 20, but I assure you that this bike has clean roots.
A cute little scooter. ;) All original or NOS parts. Steel frame. Drum brakes on both wheels. Kick right over. Just the right amount of smoke. You can see from pics it's in great condition with under 5k original miles. I also have a brand new battery that'll be included (i purchased after pictures were taken). The remaining pictures are located in this Flickr album.
Specs:
Displacement: 99.00 ccm (6.04 cubic inches)
Engine type: Single cylinder, two-stroke
Power: 10.50 HP (7.7 kW)) @ 7500 RPM
Torque: 9.76 Nm (1.0 kgf-m or 7.2 ft.lbs) @ 7000 RPM
Top speed: 104.6 km/h (65.0 mph)
Max RPM: 10000
Compression: 7.0:1
Bore x stroke: 49.5 x 51.8 mm (1.9 x 2.0 inches)
Fuel system: Carburettor. Mikuni VM19SC
Fuel control: Rotary valves
Ignition: Magneto
Lubrication system: Superlube - Oil Injection Pump
Gearbox: 5-speed
Transmission type, final drive: Chain
Clutch: Wet Plate
Fuel consumption: 3.92 litres/100 km (25.5 km/l or 60.01 mpg)
Exhaust system: Single stainless steel pipe
Physical measures and capacities:
Dry weight: 84.4 kg (186.0 pounds)
Power/weight ratio: 0.1245 HP/kg
Overall height: 1,035 mm (40.7 inches)
Overall length: 1,835 mm (72.2 inches)
Overall width: 840 mm (33.1 inches)
Ground clearance: 150 mm (5.9 inches)
Wheelbase: 1,150 mm (45.3 inches)
Fuel capacity: 7.94 litres (2.10 gallons)
Oil capacity: 1.50 litres (0.10 quarts)
Looking to get $1200 (obo) for this. I'm located in Bridgeport, CT. Bribe me properly ( gas $ and a beer) and I might be able to deliver it to you (in the tristate area)- or at least meet you half way!
Please email me any questions!
Thank you. 8-)
running... '78 KH400, '07 KLR. In a state of repair.... '72 S2.
 Post subject: Re: 1975 KH100 for sale
PostPosted: Fri Aug 28, 2015 3:42 pm
Nice. You sure you don't want to put some new tires on it and bring it to Deals Gap next spring? That's a great "ego slayer".
PostPosted: Fri Aug 28, 2015 4:02 pm
Quote:
Valves per cylinder: 2
:think:
Looks nice, someone will get a fun ride! :thumbup:
PostPosted: Fri Aug 28, 2015 8:27 pm
Talk about ego slaying... I barely proofed the specs!
PostPosted: Sat Aug 29, 2015 2:57 pm
I like it. :thumbup:
PostPosted: Mon Aug 31, 2015 8:29 am
Love it!
Aaron
1980 KE100 (ZomBessie)
PostPosted: Sat Apr 02, 2016 2:03 pm
Now that it's getting warmer outside, maybe you guys know of someone looking for a little scooter?!
This is still for sale- it just laid in a blanket in the garage for the past 5 months!
Here is a video that I took last fall...
PostPosted: Sat Apr 23, 2016 3:12 pm
SOLD!
