It is currently Sat May 03, 2025 2:14 pm
 Post subject: spark plug wires
PostPosted: Sun Aug 16, 2015 7:18 pm
gotta replace my miss matched wires, what & where do you guys get your wires from ?????
 Post subject: Re: spark plug wires
PostPosted: Mon Aug 17, 2015 6:46 am
Lots of people buy a V8 kit from the auto parts store and get 2 sets out of it, just be sure to get solid core wires and non resistor caps. (for stock ignitions) I like the original look and buy the set from HVC Cycle. http://www.hvccycle.net/ignition-coil-wire-kits/
Last edited by ThreePipesSmokin on Mon Aug 17, 2015 11:33 am, edited 1 time in total.
PostPosted: Mon Aug 17, 2015 8:03 am
Three Pipes, you know some stuff. :clap: :clap: :clap: :D :D :D
PostPosted: Mon Aug 17, 2015 8:56 am
awesome.... exactly what i was looking for !!!!! thanks
PostPosted: Tue Aug 18, 2015 7:47 pm
If you can't find automotive solid core wires, buy a set for a tractor.
PostPosted: Wed Aug 19, 2015 9:14 am
thanks Brian , but i live on Long Island NY...no one even knows what a tractor is here ! LOL
PostPosted: Thu Aug 20, 2015 9:17 pm
Parts Unlimited sells the wire on a roll, it is the tractor type stuff.
PostPosted: Fri Sep 04, 2015 1:27 pm
Liruss
On my H2B..........you can dig the "hump" off of the coil's with a hack saw blade and pry it off, it is a peice of rubber that is epoxied........then there is a "post" to re-solder the new wire to........I used 7mm fine stranded auto type wire, 4 feet (as electrons travel on the surface of wire, not thru it.........stranded flows more current)........I then got the very nice NGK non-resistor 90 degree caps.........put the rubber hump back on the coil and re-epoxy...........get some red model paint and re-paint the coils..........took maybe 3 hours tops.......bet very nice and no splicing (I think this is only on H2's, not sure though)
I also run a zeeltronic iggy.........it has a strong blue spark.........I had to use iridium resistor plugs in that setup.......you won't
THX Phil :thumbup:
