It is currently Fri May 02, 2025 5:34 pm
PostPosted: Mon Jul 13, 2015 6:21 pm
Turns out "everything" involving the front brake system on my H2B is needing serious attention. I've found and ordered up most of what I need except, in my research, I can't get any consensus on the best replacement and source for the two brake lines.
Is there a preferred fairly accurate reproduction out there...and if so, where?
thanks
PostPosted: Sat Jul 18, 2015 3:02 pm
Slingshot Cycles was a good vendor but he is temporarily shut down.
http://slingshot-cycles.com/
Do you guys know of someone else that makes custom length brake lines?
PostPosted: Sat Jul 18, 2015 3:10 pm
Spiegler does great work and can do custom lines to any length.
“Jeff and Chris are THE MEN!”
RIP John E. Evans
PostPosted: Sat Jul 18, 2015 3:22 pm
Link to website or contact info? Thanks
PostPosted: Sat Jul 18, 2015 4:03 pm
Hi,
here is the link to the german website http://www.spiegler.de/
Robby
Who´s braking later, drives longer fast !!!!!!
_______________________________________
RD125, S1B, S1B (350cm³), S2, S3A, H1B, H2, H2, S2-R, KR1S, NS400R [GSX-R1000K1, CBR1100XX, CB 750F1]
PostPosted: Sun Jul 19, 2015 12:21 pm
I had found a set pre made on ebay some time back. Works well.
PostPosted: Fri Jul 24, 2015 2:47 pm
H1e
www.speiglarusa.com........they are about 5 miles from my house.......I went up and waited 20 min while they made my brake line
NOTE: I have the superbike low rise bars on my bike, maybe 3" rise, order this from Speigler, talk to Dave 937-291-1735 ($63)
NOTE: Below is for a single EX caliper hose......but this gives you an idea of how to order after you measure your lines (2 I beleive)
Left side 2" longer is 851mm-002-004 (002 is 20 degree, 004 is 45 degree)
Right side same as stock EX hose probably would be 800mm-002-004
THX Phil :thumbup:
