It is currently Fri May 02, 2025 7:44 am
 Post subject: caliper piston
PostPosted: Mon Jun 08, 2015 7:06 pm
i recently bought 3 brake caliper pistons from 2 different sources & brands & all 3 are a little taller then the original stock pistons, will this be a problem if i use them ? ( i need 2 more)
 Post subject: Re: caliper piston
PostPosted: Mon Jun 08, 2015 7:15 pm
I don't think it will be a problem.... but that is guesswork.
I believe they are Z1 pistons.
PostPosted: Mon Jun 08, 2015 7:25 pm
i think you are right but they are advertised as h1 or s3 ...thanks
PostPosted: Mon Jun 08, 2015 7:31 pm
the ones that I bought, were 1mm taller than stock.
if you use new pads and use the shims; they are tight.
I cut 1mm from mine.
PostPosted: Mon Jun 08, 2015 7:34 pm
Don't always believe what aftermarket vendors say are correct applications.... I guess you already found that out.
The KH are the same as Z1.
PostPosted: Tue Jun 09, 2015 11:55 pm
they are 1.2mm taller , if i remove the alum ring spacer from behind the pad with the screw they work better....what purpose does that ring serve ???
PostPosted: Wed Jun 10, 2015 5:30 am
Is this what you refer to?
http://3cyl.com/mraxl/partid/list2/43076-001.jpg
If so, that is to reduce/eliminate brake squeal.
PostPosted: Wed Jun 10, 2015 9:34 pm
X
Last edited by warehouse1001 on Mon May 15, 2017 10:50 pm, edited 1 time in total.
PostPosted: Sat Jul 25, 2015 4:54 pm
HVC caliper pistons are good. There is a variation among vendors for the height dimension on replacement aftermarket pistons.
3 H2's, all stock
H2B, converted to H2C
75 Paint & Decals by Brian H
75 Euro Seat by Tony O'Connor
