It is currently Thu May 01, 2025 9:13 pm
 Post subject: Re: Spark Plugs?
PostPosted: Tue Jun 02, 2015 12:16 pm
I would go at least 10 or cooler. Do you have an iggy retard? And keep the clutch covered, these motors do not like WFO for long periods of time.
PostPosted: Tue Jun 02, 2015 12:36 pm
No retard yet (I was running Nev's box but it failed after 10+ years so have Jim's replacement now.) I like to run a bit rich, especially pilots, and have a CHT setup.
PostPosted: Tue Jun 02, 2015 1:04 pm
I would recommend a Zeel retard system. And even rich crankcase heating can cause seizure problems.
PostPosted: Tue Jun 02, 2015 1:09 pm
Zeel has a nice delay unit that plugs in between the stock pickups and a stock CDI system, or the one you have from me.
PostPosted: Tue Jun 02, 2015 1:39 pm
I've been thinking about the Zeel but haven't researched it yet. Is there a vendor Stateside? I've run the bike three times so far but never with this (potential) power output. Last time out (end of April) it was wicked cold and I was still wayyy rich (wouldn't even accept full throttle in higher gears) but I ran out of time/weather to test/work on it. The bike only ran 100 mph.
John, I'm not exactly sure what you mean by rich crankcase heating (think I know but don't want to guess.) Can you please elaborate?
PostPosted: Tue Jun 02, 2015 2:12 pm
You said you were running rich, which runs a bit cooler, but does not compensate for crankcase heating.......
PostPosted: Tue Jun 02, 2015 5:43 pm
Aha, yes, colder is in order for the full on application, and do what John suggested, will help immensely.
PostPosted: Tue Jun 02, 2015 6:58 pm
I run BR9HIX right out of the box. A bit pricey, but well worth it. Just go a little colder as suggested.
PostPosted: Tue Jun 02, 2015 7:14 pm
http://fastfromthepast.com sells the Zeel units. You need to look at the VCDI-30s unit.
PostPosted: Tue Jun 02, 2015 8:53 pm
Does this wire up with stock ignition?
And I presume it requires a charged battery at all times?
