It is currently Wed Apr 30, 2025 10:45 pm
 Post subject: H2 clutch slipping
PostPosted: Wed May 09, 2012 3:14 pm
Can I cure my clutch slipping blues with a simple spring upgrade? I called redline and haven't heard back from him. The clutch looked fine when apart, so I'm guessing it's the extra hp.
 Post subject: Re: H2 clutch slipping
PostPosted: Wed May 09, 2012 3:37 pm
There are a couple of things to look at before you jump to new springs, if you haven't already...
- type of oil
- plate thickness
- pressure plate orientation
- actuator adjustment
- scuff steel plates
PostPosted: Thu May 10, 2012 3:09 am
And also a very common one is if the steels have been overheated they can warp and drastically reduce the mating face area, so check them for flatness too.
PostPosted: Mon May 14, 2012 3:17 pm
Ill get on this when it comes apart to replace that side of the engine :-(
PostPosted: Mon May 14, 2012 5:20 pm
Oil made the difference for me - went to Gearsaver 80 - problem solved.
PostPosted: Fri Aug 24, 2012 7:31 am
- type of oil
- plate thickness
MRAXL.....Can you please elaborate on pressure plate orientation? Are you referring to the dot being lined up? just trying to expand my knowledge base a little... :clap:
PostPosted: Fri Aug 24, 2012 7:57 am
Yes, as below
PostPosted: Fri Aug 24, 2012 8:57 am
That heavy of an oil in the transmission can cost some horsepower.
Not really an issue on the street though......
steve
PostPosted: Fri Aug 24, 2012 8:58 am
80 weight gear oil is not heavy.
PostPosted: Wed Jun 05, 2013 2:17 pm
I had a severe clutch slip problem over 5,000 rpm with my green 73 H2-A years ago (Leo knows which bike). I simply chucked the steel plates out, fitted seven H1 steel plates instead with an extra H2 friction plate and problem solved!
