It is currently Fri May 02, 2025 10:48 pm
 Post subject: H2 cylinders
PostPosted: Mon Sep 08, 2014 3:57 pm
Only the cylinders are for sale. Here's a picture of the complete engine which was rebuilt around 2010 for the former owner.
I sent the cylinders and heads to Scott Clough for porting and other work. The cylinders are on 73 mm. Scott told me the piston to cylinder clearance was too high. The cylinders can be: 1) Bored to 73.5 mm, which is the largest overbore available; 2) Resleeved (big bucks); 3)Nikasil coated to 73.5mm and possibly back to 73mm.
When I received the bike I took the heads off and the cylinders were super clean. I doubt the former owner put more than a couple of hundred miles on them with the new pistons. I put about 2,000 miles on them, pretty easy miles and always with filters.
When Scott looked at the cylinders he said it looked like the motor was run without an air filter. The pistons were scuffed and the clearances opened up, probably from piston skirt collapse. I don't know why the piston/wall clearance opened up and the pistons got scuffed. My best guess is that the company who bored the cylinders used too much clearance.
Instead of working with these cylinders, I sent another set to Scott.
These cylinders are at his shop, along with the pistons, rings etc. Sorry I don't have a picture of just the cylinders, I didn't think that I would be putting them up for sale.
So if you want a set of relatively inexpensive cylinders and want to have Scott work on them, you'll save some money on shipping. The exteriors look nice, they were bead blasted when the motor was rebuilt. I believe they are 1972-1973 tapered cut out, please confirm with Scott.
Here's Scott's website with his contact info: http://home.earthlink.net/~scloughn/
If interested PM me. $200 obo for the set, waiting for you at Scott's shop. This is for the set of cylinders and the pistons if you want them.
 Post subject: Re: H2 cylinders
PostPosted: Tue Sep 30, 2014 3:26 pm
Bump nobody wants a low priced set of H2 cylinders on 73mm?
PostPosted: Tue Sep 30, 2014 3:52 pm
I like the Nikasil option, since they probably wouldn't ever have to be rebored after that. My H2 is at 73.0 mm now too, so it's a 790cc engine.
PostPosted: Fri Oct 03, 2014 6:34 am
Do you know if the cylinders have any broken fins on them? I may be interested. Thank you for your time.
PostPosted: Fri Oct 03, 2014 4:22 pm
No broken or chipped fins.
PostPosted: Sun Jan 11, 2015 8:30 pm
Somebody just bought these '73 cylinders at 73mm and a broken fin for $300 + shipping today on E-bay: http://www.ebay.com/itm/1973-KAWASAKI-T ... true&rt=nc
I'll sell my cylinders for half that, $150 and they're at Scott Clough's shop. If you have Scott do the work, half of the shipping is already covered.
PostPosted: Mon Jan 12, 2015 12:54 pm
does anyone know How much is the nikasil option ?
PostPosted: Mon Jan 12, 2015 1:10 pm
resleeved them is the best option, 73.5 mm gives a very thiner sleeve.
