It is currently Tue May 06, 2025 10:30 pm
PostPosted: Sun Apr 12, 2015 11:40 am
Anyone have a nice one for sale? Also, do these make a substantial difference from the nylon type?
Thanks
PostPosted: Sun Apr 12, 2015 2:22 pm
Want an easy pull even with heavy duty springs?
Dave is taking orders for hydraulic ones that have gotten excellent reviews.
http://triplescanada.proboards.com/thre ... s-clutches
PostPosted: Sun Apr 12, 2015 3:24 pm
Thanks
The six spline nylon is an improvement over the 4 spline, and the BB has the benefit of reported smoother operation and also has no nylon to eventually crack over time.
I you can tack/spot weld or know someone who can for you, I have a few BB releases that are fine except have typical wear where the main pivot arm is pressed to the actuator (just aft of the adjuster nut). If you are interested, send me a pm.
PostPosted: Sun Apr 12, 2015 6:54 pm
Also, what year was this offered for the H2? 74? 75?
Thanks
PostPosted: Sun Apr 12, 2015 7:20 pm
remember if your motor didn't come with one, you have to space out the ball bearing one or you will destroy the seal. Then you have to split the cases.
PostPosted: Sun Apr 12, 2015 10:42 pm
Thanks
75 H2-C, but as John pointed out, can be used on other years as long as correct "matching" seal is used.
